| Author
Matrix Ltd
| Version
1.0
| Category
Keypad
Keypad (Cursor 3x3) component
A preset keypad component with up, down, left and right cursors, and a selection of function keys, in a 3 by 3 matrix. Return values (Index or Number) are... 0 = F1, 1 = Up, 2 = F3 3 = left, 4 = OK, 5 = right 6 = F2, 7 = down, 8 = F4. 255 = No key pressed.
Please click here for the component source code: FC_Comp_Source_Keypad_Cursor.fcfx
WaitPressed
| Blocking call that waits for one of the keys on the keypad to be pressed. The index of the key that was pressed is passed back to the user.
- BYTE
GetAscii
| Gets the ASCII value for the current keypress. If no key is pressed then the macro returns the value 255.
- BYTE
GetString
| Gets the ASCII value for the current keypress and returns in the form of a string. If no key pressed then the macro returns a null string.
- STRING
GetNumber
| Gets the numeric value for the current keypress. If no key pressed then the macro returns the value 255.
- BYTE
GetIndex
| Gets the index value for the current keypress. If no key pressed then the macro returns the value 255.
- BYTE
WaitReleased
| Blocking call that waits for the keys on the keypad to be released. If no key is pressed then the function will return immediatley.
Dimensions
Keys
| Number of columns (left to right) in the array of keys. Must be a value from one to four.
Return Values
ASCII
| A list of return values for the 'GetString' and 'GetASCII' macros. Enter a string with one character per key, in order of key scanning. Columns are counted first (left-to-right), then rows (direction set by the 'First Row' property) e.g. for a 2*2 grid, the order would be... [Row0, Column0], [Row0,Column1], ][Row1, Column0], [Row1, Column1]
Numbers
| A list of return values for the 'GetNumber' macro. Enter a comma separated list with one integer value per key, in order of key scanning. Columns are counted first (left-to-right), then rows (direction set by the 'First Row' property) e.g. for a 2*2 grid, the order would be... [Row0, Column0], [Row0,Column1], ][Row1, Column0], [Row1, Column1]
Output Mode
Port
Backplate Colour
Button 1
Key colour
| Set the colour of the key body here. This is applied to all objects making up a key, including the background colour of any text labels.
Label colour
| Set the colour for the default 'ASCII' text label on the key-cap. This setting will be ignored if a bitmap is set for the key label.
Button 2
Key colour
Up arrow colour
Button 3
Key colour
Label colour
Button 4
Key colour
Left arrow colour
Button 5
Key colour
Label colour
Button 6
Key colour
Right arrow colour
Button 7
Key colour
Label colour
Button 8
Key colour
Down arrow colour
Button 9
Key colour
Label colour
