Component: Simulation LED Template (Indicators)
Revision as of 14:41, 16 January 2023 by Wiki bot (talk | contribs)
Version 1.4
Category Indicators
Simulation LED Template component
Base for creating simulation LEDs and other on/off visual indicators. Choose a 'Target Object' that will change colour when the pin changes; if multiple objects must change color, group them, and target the group. When 'Auto off color" is selected, changing the 'on color' will automatically choose an off color by reducing the intensity of the on color.
Please click here for the component source code: FC_Comp_Source_LED_Sim_Base.fcfx
TurnOn
Turn the LED off.
TurnOff
Turn the LED off.
Target Object
Set a target object to be the illuminating part of the LED. To change the colour of multiple objects, group them first, then target the group.
Decide what label to show... None - no labels are displayed Name - shows the component's name Property - shows a property value of the component (a field for the property name will appear below)
On Color
The color of the LED when it is turned on.
Off Color
The color of the LED when it is turned off.
Auto Off Color
When this is selected, the off color is automatically set to a reduced intensity version of the on color.
Startup State
Default state of the indicator when loading the project or starting the simulation runtime.
