Component: GLCD Bitmap Drawer FAT (Graphical Library)
Revision as of 14:41, 16 January 2023 by Wiki bot (talk | contribs) (Created page with "{| style="width:50%" |- | width="20%" style="color:gray;" | Author | Matrix TSL |- | width="20%" style="color:gray;" | Version | 2.2 |- | width="20%" style="color:gray...")
Version 2.2
Category Graphical Library
GLCD Bitmap Drawer FAT component
A component to simplify the process of drawing bitmap images to a graphical display. Reads Bitmap files directly from a SD card formatted with a FAT file system. Compatible with 24-bit & Monochrome Bitmaps. The gLCD object property specifies which LCD component to draw the bitmap to. Compatible with GLCD, NeoPixel, MIACv3, HT16K33
Please click here for the component source code: FC_Comp_Source_Lib_Draw_Bitmap_FAT.fcfx
Fc9-comp-macro.png GetHeight
Returns the height of the loaded bitmap file in pixels.
The filename of the bitmap we want to measure
Fc9-comp-macro.png GetWidth
Returns the width of the loaded bitmap file in pixels.
Fc9-comp-macro.png SetTransparentColour
Sets the transparency colour, the colour that is not drawn when transparency is enabled.
Fc9-u8-icon.png - BYTE R
Fc9-u8-icon.png - BYTE G
Fc9-u8-icon.png - BYTE B
Fc9-comp-macro.png Display_BMP
Draws the bitmap image from ROM onto the display at the corrdinates X and Y. Return Values: 0=OK, 1=ColourDepthNotSupported, 237=FileNotFound
Bitmap file to open from current directory on SD card 8.3 format
Fc9-u16-icon.png - UINT X
X Axis coordinate, specifies the location of the left edge of the bitmap image
Fc9-u16-icon.png - UINT Y
Y Axis coordinate, specifies the location of the top edge of the bitmap image
0=Normal, 1=90 Degrees CW, 2=180 Degrees, 3=270 Degrees CW
Fc9-u8-icon.png - BYTE Transparency
0=Off, 1=On Don't Draw Any Pixels which match the transparent colour
Fc9-u8-icon.png - BYTE Flip
0=Normal, 1=FlipWidth, 2=FlipHeight, 3=FlipBoth
Fc9-comp-macro.png Display_BMP_Fast
Draws the bitmap image from ROM onto the display at the corrdinates X and Y. Attempts to draw a row at a time by not forcing coordinates for every pixel so may not work on some displays. Return Values: 0=OK, 1=ColourDepthNotSupported, 237=FileNotFound
Fc9-type-16-icon.png GLCD LinkTo
Fc9-type-16-icon.png File LinkTo
Fc9-type-7-icon.png ColourDisplay
Automatically detects if the graphical LCD object is colour or monochrome
