Component: Digital Potentiometer (MCP41XXX / MCP42XXX) (Analog Output)
Revision as of 14:42, 16 January 2023 by Wiki bot (talk | contribs) (Created page with "{| style="width:50%" |- | width="20%" style="color:gray;" | Author | Matrix TSL |- | width="20%" style="color:gray;" | Version | 1.0 |- | width="20%" style="color:gray...")
Category Analog Output
Digital Potentiometer (MCP41XXX / MCP42XXX) component
The MCP41XXX and MCP42XXX device range supports up to 2 digital potentiometer outputs. With 256 possible output resistance values for each channel.
Please click here for the component source code: FC_Comp_Source_MCP41xxx_42xxx_Digital_Pot.fcfx
SetWiper
Sets the value of a single wiper
- BYTE Index
Range: 0-2 / 0=CH0, 1=CH1, 2=CH0 AND CH1
- BYTE Value
256 Taps Range: 0-255
Startup the SPI peripheral ready for communications.
SPI Properties
SPI Channel selector
Prescale
Prescale option selector
MOSI
MOSI Remap Pin
MISO
MISO Remap Pin
CLK
CLK Remap Pin
CS / SS
Device Properties
Number of Outputs
Number of Taps
Simulate Comms
