Component: Digital Potentiometer (MCP45XX / MCP46XX) (Analog Output)
Revision as of 14:42, 16 January 2023 by Wiki bot (talk | contribs)
Category Analog Output
Digital Potentiometer (MCP45XX / MCP46XX) component
The MCP45XX and MCP46XX device range supports up to 2 digital potentiometers or rheostat outputs. 129 or 257 possible output resistance values for each channel.
Please click here for the component source code: FC_Comp_Source_MCP45xx_46xx_Digital_Pot.fcfx
IncrementWiper
Increments a single volatile wiper value
- BYTE Index
Range: 0-1
DecrementWiper
Decrements a single volatile wiper value
- BYTE Index
Range: 0-1
SetWiper
Sets the value of a single wiper
- BYTE Index
Range: 0-1
- UINT Value
129 Taps Range: 0-128 / 257 Taps Range: 0-256
- BOOL MemoryType
0=Volatile, 1=Nonvolatile
ReadAddress
Reads a value from one of the registers on the device
- BYTE Address
Range: 0-15
WriteAddress
Writes a value to one of the registers on the device
- BYTE Address
Range: 0-15
- UINT Value
Range: 0-256
Startup the I2C peripheral ready for communications.
I2C Properties
Channel selection
SDA
SCL
Baud Select
Baud rate to be used
Stop Delay
Device Properties
Number of Outputs
Number of Taps
Address Bits
Simulate Comms
