Component: MIDI (Comms: System)
Revision as of 14:42, 16 January 2023 by Wiki bot (talk | contribs)
Author Matrix Ltd.
Version 2.0
Category Comms: System
MIDI component
Low level routines for controlling or interacting with a standard MIDI interface.
Please click here for the component source code: FC_Comp_Source_MIDI.fcfx
Basic example to play a series of notes getting higher in pitch and then going down in pitch. This repeats in a loop and each time the loop repeats the instrument is changed. The current note and instrument are displayed on the LCD. FC6 Icon.png MIDI Test File MidiDemoRun.jpg
The MIDI component during simulation has functionality to allow it to work with MIDI synthesizers installed on your PC.
To select your software or hardware synthesizer select from the property selector.
If you don't have a MIDI interface installed then IP MIDI seems to be a good option that works well.
Once installed the MIDI output should play through your computer speakers.
The console window can be used to view the MIDI data as it is sent out and received.
The MIDI component during embedded operation will communicate using a UART serial channel. An EB021 MIDI E-block is available to allow standard MIDI cables to be connected up to a system.
Fc9-comp-macro.png SendMIDI
Sends a MIDI packet consisting of up to three bytes of information,
Fc9-u8-icon.png - BYTE Status
MIDI Status Byte - Used for commands such as NoteOn, NoteOff etc.
Fc9-u8-icon.png - BYTE Data1
MIDI Data Byte - Used as a parameter specific to the specified command
Fc9-u8-icon.png - BYTE Data2
Fc9-comp-macro.png SendPitchChange
Sends out a pitch change command on the specified channel.
Channel to send the pitch change to
Fc9-u16-icon.png - UINT Pitch_Change
New pitch value to use, Default 0x2000
Fc9-comp-macro.png SendNoteOff
Sends a note off command using the channel, note and velocity specified.
Fc9-u8-icon.png - BYTE Note
Fc9-u8-icon.png - BYTE Velocity
Fc9-comp-macro.png SendControl
Sends a control command using the channel, controller and value specified.
Fc9-u8-icon.png - BYTE Controller
Fc9-u8-icon.png - BYTE Value
Fc9-comp-macro.png SendNoteOn
Sends a note on command using the channel, note and velocity specified.
Fc9-comp-macro.png ReceiveMIDI
Waits for the time specified in the timeout parameter for an incoming MIDI message. Returns 0 to indicate a timeout, otherwise returns the first value from the MIDI message.
Fc9-u8-icon.png - BYTE Timeout
Fc9-comp-macro.png SendPolyPressure
Sends a note press with an associated polyphonic pressure value.
Fc9-u8-icon.png - BYTE Pressure
Fc9-comp-macro.png ReadData
Fc9-u8-icon.png - BYTE Idx
Fc9-comp-macro.png SendPatch
Fc9-u8-icon.png - BYTE Instrument
Fc9-comp-macro.png SendChannelPressure
Fc9-comp-macro.png Initialise
Initialises the MIDI component and sets up the UART.
Fc9-type-16-icon.png Channel
Fc9-type-16-icon.png Baud Options
Fc9-type-7-icon.png Use TX
Selects if the Transmit pin is used by the component. Yes: The TX pin is active and used to transmit data for the UART. No: The TX pin is disabled and free to be used as general I/O.
Fc9-type-5-icon.png TX
Fc9-type-7-icon.png Use RX
Selects if the Receive pin is used by the component. Yes: The RX pin is active and used to receive data for the UART. No: The RX pin is disabled and free to be used as general I/O.
Fc9-type-5-icon.png RX
Fc9-type-16-icon.png Use Flow Control
Fc9-type-5-icon.png RTS
Pin to be used for Request To Send handshake function Output from target micro to inform remote device we are ready to receive data. Low = Ready to receive data High = Not ready to receive data
Fc9-type-5-icon.png CTS
Pin to be used for Clear To Send handshake function. Input to target micro to inform when the remote device is ready to transmit data. Low = Ready to transmit data High = Not ready to transmit data
Fc9-conn-icon.png Simulation
Fc9-type-10-icon.png Label
Fc9-type-7-icon.png MIDI Output
Decides if we are using special MIDI output or standard Serial/API Output. Yes: We send the simulation data via a MIDI interface. No: We send the simulation data via the standard COM/API interface.
Fc9-type-16-icon.png MIDI Port
Fc9-type-21-icon.png Console Columns
Fc9-type-16-icon.png Data Source
