Component: SCADA (Dummy) (SCADA Slaves)
| Category | SCADA Slaves |
SCADA (Dummy) component
Dummy SCADA Slave component to enable injector referencing. Supports: Digital IO / ADC / I2C / SPI / PWM See Flowcode Help Wiki for firmware.
Please click here for the component source code: FC_Comp_Source_OLD_API_Slave_Dummy.fcfx
| I2CInitialise | |
| Initialsie the I2C module ready for communications | |
| IOGetInputPin | |
| Pin | |
| Range: 0-13 | |
| I2CRestart | |
| Put the I2C Module into Restart mode | |
| I2CStart | |
| Put the I2C Module into Start mode | |
| SPITransfer | |
| Transfer a byte using the SPI bus | |
| DataOut | |
| I2CReceive | |
| Receive a byte using the I2C bus | |
| Last | |
| I2CStop | |
| Put the I2C Module into Stop mode | |
| SPIPrescaler | |
| Modify the speed of the SPI bus | |
| Prescaler | |
| Range: 0-2 | |
| IOSetOutputPin | |
| Pin | |
| Range: 0-13 | |
| State | |
| Range: 0-1 | |
| SPIInitialise | |
| I2CSend | |
| DataOut | |
| Properties |
