Component: Servo Motor Template (Mechatronics)
Revision as of 14:42, 16 January 2023 by Wiki bot (talk | contribs)
Version 1.1
Category Mechatronics
Servo Motor Template component
Base component for creating custom servo motor simulations. Recieves messages from the the 'Servo Controller' component. Macro 'SetTarget' allows external objects to be moved by the servo for mechanical simulations.
Please click here for the component source code: FC_Comp_Source_Servo_Motor_Base.fcfx
SetTarget
Set a panel object to be 'connected' to the servo's. The connected object will then move as if connected mechanically to the servo's actuator.
- HANDLE Target
Object to be moved by the motor
Moving Part
Set an object on the System Panel to be the servo's actuator. The object's position at the moment of selection is taken to be the 'rest' position of the actuator - the maximum and minimum angles will be measured from this position.
Axis Object
Set a panel object to be the centre of rotation of the servo's actuator.
Move Around
Set the axis around which the actuator will revolve. If an 'Axis Object' is chosen, this will be a local axis of the chosen object, otherwise it will be the current world axes.
Movement Type
Minimum (degrees)
Angle that the servo turns when the PWM signal is at its minimum. Measured from the actuator object's 'rest' position, chosen at the time of connecting the object.
Maximum (degrees)
Angle that the servo turns when the PWM signal is at its maximum. Measured from the actuator object's 'rest' position, chosen at the time of connecting the object.
