Component: Switch Push Button (Switch)
Revision as of 14:43, 16 January 2023 by Wiki bot (talk | contribs)
Category Switch
Switch Push Button component
A simple digital push switch allowing latched and none latched operation. In embedded mode displays the connecting pin and pin status.
Please click here for the component source code: FC_Comp_Source_Switch_Push_Button_2dgi.fcfx
Here is an example Flowcode program to read the value of a switch. Switch
(5V / 11K) * 10K = 4.54545V
WaitUntilHigh
Waits until the switch is in state 'high' The interpretation of 'high' depends on the polarity
SetState
Sets the switch to be on or off.
- BOOL State
The new state of the switch (true=on, false=off)
WaitUntilLow
Waits until the switch is in state 'low' The interpretation of 'high' depends on the polarity
Switch Settings
Connection
Polarity
Debounce
Latching
Component Label
Label Colour
Show Connection Label
Show Pin Value
Style
Type
On Label
Off Label
