Component: TCP Template (Comms: Networking)
Revision as of 14:43, 16 January 2023 by Wiki bot (talk | contribs)
Author Matrix Ltd.
Version 2.2
Category Comms: Networking
TCP Template component
Base TCP/IP component with simulation only interface to allow TCP/IP style network communications in simulation. Suitable for inheriting
Please click here for the component source code: FC_Comp_Source_TCPIP_Base.fcfx
Additional examples can be found in the “Apps and Bundles” section of this Wiki:
Internet Application Guide
Wireless LAN Application Guide
Fc9-comp-macro.png TxSendMyIP
This macro fills the specified channel's transmit buffer with 4 bytes of data representing this Internet E-Block's IP address as specified in the component's property page.
Specifies the communications channel 0-3
Fc9-comp-macro.png RxMatchMyIP
This macro returns a non-zero value when the next 4 bytes of data in the specified channel's reception buffer are the same as the Internet E-block's IP address.
Fc9-comp-macro.png RxMatch_4_Bytes
This macro returns a non-zero value when the next 4 bytes of data in the specified channel's reception buffer are the same as those passed as parameters. There are similar functions that check for 2 bytes and 6 bytes.
Fc9-u8-icon.png - BYTE Byte1
Specifies the value of the first byte
Fc9-u8-icon.png - BYTE Byte2
Specifies the value of the second byte
Fc9-u8-icon.png - BYTE Byte3
Specifies the value of the third byte
Fc9-u8-icon.png - BYTE Byte4
Specifies the value of the fourth byte
Fc9-comp-macro.png SetPropertyVal
Fc9-string-icon.png - STRING Property
Fc9-string-icon.png - STRING Value
Fc9-comp-macro.png SetMyIP
This macro sets up the Internet E-Block's own IP address. In most circumstances, this macro will not be required as the IP address setting in the component property page will remain constant throughout your application.
Fc9-u8-icon.png - BYTE IP0
First Byte of IP address
Fc9-u8-icon.png - BYTE IP1
Second Byte of IP address
Fc9-u8-icon.png - BYTE IP2
Third Byte of IP address
Fc9-u8-icon.png - BYTE IP3
Fourth Byte of IP address
Fc9-comp-macro.png TxSendString
This macro fills the specified channel's transmit buffer with data. It can fill the buffer with a single byte of data, or with a string of information.
Data byte to append to Tx buffer.
Fc9-comp-macro.png SecureWrite
Attempts to write max number of bytes to the secure socket from the buffer. Returns actual number of bytes written.
Fc9-string-icon.png - STRING buffer
Fc9-s16-icon.png - INT max
Fc9-s16-icon.png - INT Return
Fc9-comp-macro.png Connect
Attempt to connect to the given address and port. First open a socket on the local device using the Socket function and check that it is successful.
Fc9-string-icon.png - STRING Address
Remote destination address
Fc9-u16-icon.png - UINT Port
Remote destination port
Fc9-comp-macro.png ForcePropEvent
Allows the property event to be fired, doing things like fetching the correct IP for the network interface.
Fc9-comp-macro.png Receive
Receive data into the data buffer. Returns the number of bytes received
Data byte buffer to receive the data
Fc9-u16-icon.png - UINT Count
Maximum number of bytes to read
Fc9-comp-macro.png SendTo
Send data to a destination host. Returns the number of bytes sent.
Data byte buffer to send
Number of bytes to send
Fc9-comp-macro.png SecureConnect
Connect securely to host and port. e.g. “www.bbc.co.uk:443” Returns 1 if successful, 0 if not
Fc9-string-icon.png - STRING host
Host:Port as string
Fc9-comp-macro.png RxReadHeader
Once data in a particular channel has been received, the header will be filled with information about the received data. This macro will return the information in the header. The idx parameter specifies which byte of information in the header to read
Fc9-u8-icon.png - BYTE Idx
Specifies the byte index to return
Fc9-comp-macro.png RxSkipBytes
Often when receiving data packets, it may be necessary to ignore large sections of the data. This can be achieved by reading each byte individually (and ignoring the returned data), but a better way is to use this Rx_skipbytes macro.
Fc9-u8-icon.png - BYTE Count
Specifies how many bytes to skip
Fc9-comp-macro.png CreateIPSocket
Note that sockets on up to 4 channels can be simultaneously opened and these channels are numbered 0 to 3. Note that sockets with different modes can be opened on different channels.
Fc9-u8-icon.png - BYTE Protocol
Specifies which IP protocol to use
Fc9-u8-icon.png - BYTE Broadcast
Allows broadcast type packets to be sent and received
Fc9-comp-macro.png SetDestination
This is used in IP and UDP modes to set the destination of the intended data transfer. The destination IP address needs to be set for both IP and UDP modes.
Fc9-u8-icon.png - BYTE Dst_IP0
Specifies the first byte of an IP address
Fc9-u8-icon.png - BYTE Dst_IP1
Specifies the second byte of an IP address
Fc9-u8-icon.png - BYTE Dst_IP2
Specifies the third byte of an IP address
Fc9-u8-icon.png - BYTE Dst_IP3
Specifies the fourth byte of an IP address
Fc9-u8-icon.png - BYTE Dst_Port_Hi
Port High Byte
Fc9-u8-icon.png - BYTE Dst_Port_Lo
Port Low Byte
Fc9-comp-macro.png GetConsole
Obtain the console instance for the TCP/IP base.
Fc9-comp-macro.png TxStart
This macro indicates the start of data transmission for the specified buffer. In TCP mode, data transmission can only begin once the socket has become established. In other modes, data transmission can occur as soon as the socket has been opened.
Fc9-comp-macro.png RxReadByte
A call to this macro will return a byte of data in the reception buffer of the specified channel. It will also internally increment a pointer to that data so that the next call to 'RxReadByte' (or any other read function) will read the next byte
Fc9-comp-macro.png CreateUDPSocket
This macro creates a socket for sending and receiving UDP data.
Fc9-u8-icon.png - BYTE Src_Port_Hi
Port High Byte
Fc9-u8-icon.png - BYTE Src_Port_Lo
Port Low Byte
Send data
Fc9-comp-macro.png RxMatch_6_Bytes
This macro returns a non-zero value when the next 6 bytes of data in the specified channel's reception buffer are the same as those passed as parameters. There are similar functions that check for 2 bytes and 4 bytes.
Fc9-u8-icon.png - BYTE Byte5
Specifies the value of the fifth byte
Fc9-u8-icon.png - BYTE Byte6
Specifies the value of the sixth byte
Fc9-comp-macro.png RxMatch_2_Bytes
This macro returns a non-zero value when the next 2 bytes of data in the specified channel's reception buffer are the same as those passed as parameters. There are similar functions that check for 4 bytes and 6 bytes.
Fc9-comp-macro.png SecureClose
Close the secure connection
Fc9-comp-macro.png RxReadString
A call to this macro will return a byte of data in the reception buffer of the specified channel. It will also internally increment a pointer to that data so that the next call to 'Rx_readbyte' (or any other read function) will read the next byte
Fc9-u8-icon.png - BYTE Length
Fc9-comp-macro.png TxEnd
Once the transmit buffer has been filled with data, call this macro to actually send the data.
Fc9-comp-macro.png SetChannel
Dictates the TCP IP channel used for socket communications allowing for multiple parrallel communication streams to co-exist, Used by the network comms component to drive the TCP IP runtime comms
Range: 0 to 3
Fc9-comp-macro.png Listen
Bind the socket to a port on the local host and set to listen mode. First open a socket on the local device using the Socket function and check that it is successful.
Fc9-comp-macro.png CreateTCPSocket
This macro creates a socket for sending and receiving TCP data.
Port High Byte
Port Low Byte
Fc9-comp-macro.png RxDataAvailable
This macro is used to check whether or not data has been received by the Internet E-Block. A return value of zero indicated that no data has been received. A positive return value indicates that data is available.
Fc9-comp-macro.png SocketOpen
Attempts to create a socket on the local device. Type =0 for TCP, =1 for UDP This must be successfully done before attempting connection with a remote destination. Returns 1 if successful, 0 if not.
Fc9-u8-icon.png - BYTE Type
Type of socket to create
Fc9-comp-macro.png TxSendByte
Fc9-u8-icon.png - BYTE Data
Fc9-comp-macro.png TCPListen
This macro puts a previously opened TCP channel in "passive open" mode. This is the required mode when writing a TCP server application (e.g. a web server to display HTML web pages).
Fc9-comp-macro.png RxFlushData
Once data reception has been completed, this macro should be called to discard the data packet and allow other data packets to be read.
Fc9-comp-macro.png TCPConnect
This macro puts a previously opened TCP channel in "active open" mode. This is the required mode when writing a TCP client application (e.g. using SMTP to send an email).
High Byte of destination port
Low Byte of destination port
Fc9-comp-macro.png GetPropertyVal
Fc9-comp-macro.png SocketClose
Close the socket
Fc9-comp-macro.png SecureRead
Attempts to read max number of bytes from the secure socket into the buffer. Returns actual number of bytes read.
Fc9-comp-macro.png RxMatchMyMAC
This macro returns a non-zero value when the next 6 bytes of data in the specified channel's reception buffer are the same as the Internet E-block's MAC address entered in the component's property page.
Fc9-comp-macro.png AcceptOpen
Fc9-comp-macro.png RxDataSize
This macro is used to detect the size of data collected by the Rx_data_available macro.
Fc9-comp-macro.png TxSendMyMAC
This macro fills the specified channel's transmit buffer with 6 bytes of data representing this Internet E-Block's MAC address as specified in the component's property page.
Fc9-comp-macro.png CreateMACSocket
This macro creates a socket for sending and receiving Ethernet data using raw data.
Fc9-u8-icon.png - BYTE Promiscuous
Receive everything (1) or just data bound for your MAC (0)
Allows broadcast messages to be accepted (1) or rejected (0)
Fc9-u8-icon.png - BYTE Error
Allowsmessages with errors to be accepted (1) or rejected (0)
Fc9-comp-macro.png AcceptClose
Close the accept socket
Fc9-comp-macro.png SecureInit
Call once to initialise the secure socket funtionality
Fc9-comp-macro.png GetSocketStatus
This returns the state of the requested channel's socket.
Fc9-comp-macro.png Initialise
Fc9-comp-macro.png TCPClose
When an established TCP connection has finished transmission of data, either the local application (i.e. your code) or the remote application (i.e. the application at the other end of the connection) can initiate closure of the socket.
Fc9-type-10-icon.png Hostname
Local PC's hostname
Fc9-type-16-icon.png Network Interface
List of network interfaces connected to the PC. Sets which interface we are communicating via.
Fc9-conn-icon.png Gateway IP
Fc9-type-14-icon.png Gateway0
Gateway IP address to the Internet, auto populated from the selected interface.
Fc9-type-14-icon.png Gateway1
Fc9-type-14-icon.png Gateway2
Fc9-type-14-icon.png Gateway3
Fc9-conn-icon.png Subnet Mask
Fc9-type-14-icon.png Subnet0
Network IP subnet mask, auto populated from the selected interface.
Fc9-type-14-icon.png Subnet1
Fc9-type-14-icon.png Subnet2
Fc9-type-14-icon.png Subnet3
Fc9-conn-icon.png IP Address
Fc9-type-14-icon.png IP0
Network IP address, auto populated from the selected interface.
Fc9-type-14-icon.png IP1
Fc9-type-14-icon.png IP2
Fc9-type-14-icon.png IP3
Fc9-conn-icon.png MAC Address
Fc9-type-14-icon.png MAC0
Network MAC address, auto populated from the selected interface.
Fc9-type-14-icon.png MAC1
Fc9-type-14-icon.png MAC2
Fc9-type-14-icon.png MAC3
Fc9-type-14-icon.png MAC4
Fc9-type-14-icon.png MAC5
Fc9-conn-icon.png Notify
Generate Console Data
Fc9-type-17-icon.png Target
Sets a target object, to which User.Notify events will be sent when data is sent and received. Events are send with Message ID = this component's handle, Data: 1=Send, 2=Receive.
