API Connection.SetAn
Revision as of 13:15, 14 May 2013 by JonnyW (talk | contribs) (XML import API changes)
<sidebar>API contents</sidebar> Sets an analog value from its index, range 0->1
Class hierarchy
Connection
SetAn
UINT ChannelIx
The zero-based index of the analog channel
FLOAT Value
Value to set, 0 to 1 if BitDivide is false
BOOL BitDivide
Set to write the analog value as a full-width reading for the selected device
BOOL
Returns true if the operation is a success, else false
  • Add to a calculation icon:
    result = ::Connection.SetAn(channelix, value, false)
