Component: Circular Buffer (16-bit) (Buffer)
| Author | Matrix Ltd |
| Version | 1.5 |
| Category | Buffer |
Circular Buffer (16-bit) component
Circular buffer component allowing easy and efficient first in first out (FIFO) style data storage. Also features macros to allow you to check for specific 16-bit values.
Please click here for the component source code: FC_Comp_Source_CircularBuffer16.fcfx
| GetNumberValues | |
| Returns the number of valid 16-bit data values currently stored inside the buffer. | |
| PeekData | |
| Reads the next available 16-bit data value from the circular buffer without advancing the current index, Returns the default value if the buffer is empty. | |
| GetData | |
| Reads the next available 16-bit value from the circular buffer, Returns the default value if the buffer is empty. | |
| FlushBuffer | |
| Clears the contents of the buffer and re-initialises the index locations. | |
| GetIndexedValue | |
| Gets the value of a single 16-bit value at a known location in the buffer. Leaves the buffer contents and pointers untouched. | |
| address | |
