Component: Circular Buffer (Float) (Buffer)
| Author | Matrix Ltd |
| Version | 1.5 |
| Category | Buffer |
Circular Buffer (Float) component
Circular buffer component allowing easy and efficient first in first out (FIFO) style data storage. Also features macros to allow you to check for specific floating point values.
Please click here for the component source code: FC_Comp_Source_CircularBufferFloat.fcfx
| GetNumberValues | |
| Returns the number of valid 16-bit data values currently stored inside the buffer. | |
| PeekData | |
| Reads the next available 16-bit data value from the circular buffer without advancing the current index, Returns the default value if the buffer is empty. | |
| GetData | |
| Reads the next available 32-bit floating point value from the circular buffer, Returns the default value if the buffer is empty. | |
| FlushBuffer | |
| Clears the contents of the buffer and re-initialises the index locations. | |
| GetIndexedValue | |
| Gets the value of a single 32-bit floating point value at a known location in the buffer. Leaves the buffer contents and pointers untouched. | |
| address | |
