Component: Formula AllCode (RB4420) (Robotics)
Revision as of 14:11, 20 January 2023 by Wiki bot (talk | contribs)
Version 1.3
Category Robotics
Formula AllCode component
A component to allow all the features of the Formula AllCode robot to be investigated. Fully simulated component which can interact with simulated objects on the panel as well as control the real hardware.
Please click here for the component source code: FC_Comp_Source_FA_Source_P4.fcfx
Fc9-comp-macro.png PlayNote
Outputs a single tone from the onboard speaker for the period specified.
Fc9-u16-icon.png - UINT Note
Sets the pitch of the note in Hz. Range: 1 - 10000
Fc9-u16-icon.png - UINT Time
Time period to play the note for in milliseconds. Range: 0 - 65535 ms
Fc9-comp-macro.png LEDOn
Switches on a single LED on the front of the Formula Allcode.
Fc9-u8-icon.png - BYTE LED
Which LED to switch on, range 0-7
Fc9-comp-macro.png BluetoothTransmit
Sends a byte via the Bluetooth data connection.
Fc9-u8-icon.png - BYTE Data
Fc9-comp-macro.png LCDPrintString
Prints a string to the graphical LCD.
Fc9-u8-icon.png - BYTE X
The horizontal start pixel. Range 0-127
Fc9-u8-icon.png - BYTE Y
Y coordinate to print the string. Range 0-31
Fc9-u16-icon.png - UINT Transparent
Fc9-comp-macro.png LogoConfigure
The Logo movement may sometimes be slightly off in terms of distance or angle. Before tweaking the factory values check that the wheels are pushed well onto their shafts but not tight against the FA body. Also check the tyre is on the wheel correctly.
Fc9-f32-icon.png - FLOAT Distance
mm per encoder step. default = 0.32
Fc9-f32-icon.png - FLOAT Angle
mm of travel per degree. default = 0.7295
Fc9-comp-macro.png Stop
Stops both motors.
Fc9-comp-macro.png ReadBattery
Reads the current voltage level from the LiPo battery. Return value is the battery voltage in Volts. Take care not to run the battery too low. Voltages lower than 3.4V may damage the battery.
Fc9-comp-macro.png LEDOff
Switches off a single LED on the front of the Formula Allcode.
Fc9-comp-macro.png LCDPrintNumber
Prints a numeric value to the graphical LCD.
Fc9-u16-icon.png - UINT Number
Fc9-comp-macro.png LEDWrite
Allows control of all 8-LEDs on the front of the Formula Allcode.
Fc9-u8-icon.png - BYTE LED_Byte
8-bit binary value to write to the 8 LEDs
Fc9-comp-macro.png BluetoothCheckConnection
Checks the status of the Bluetooth connection. Returns 0 for not paired and 1 for paired.
Fc9-comp-macro.png ReadMic
Reads the current audio signal level from the on-board microphone. Return value range: 0 to 4095
Fc9-comp-macro.png AudioQueueLength
Retreives the current length of valid data within the audio queue
Fc9-comp-macro.png AudioAddToBuffer
Writes a value to the 16-bit audio output buffer.
Fc9-u16-icon.png - UINT Data
Fc9-comp-macro.png ReadSwitch
Reads the value of one of the switches from the front of the Formula Allcode.
Fc9-u8-icon.png - BYTE Switch
Which switch do we want to read 0=Left, 1=Right
Fc9-comp-macro.png CheckLine
Checks to see if a line sensor is within the master threshold distance. Returns 0 if the IR reading is below the threshold. Returns 1 if the IR reading is greater than or equal to the threshold.
Fc9-u8-icon.png - BYTE Sensor
Range: 0 to 1 - 0=Left, 1=Right
Fc9-comp-macro.png AudioStreamControl
Allows control of the audio output functionality via the onboard speaker. Data is loaded into the audio output buffer using the AddToBuffer function.
Fc9-u8-icon.png - BYTE Mode
0=Off, 8=8-bit Mode, 16=16-bit Mode
Fc9-u8-icon.png - BYTE SampleRate
Sets the sample rate 0=8KHz, 1=16KHz
Fc9-comp-macro.png SpinLeft
Spins the formula flowcode on the spot in an anticlockwise direction as seen from above.
Fc9-u8-icon.png - BYTE Power
Amount of power to use to drive motor. Range 0-100
Fc9-comp-macro.png LogoTurnLeft
Rotates the robot left by a specific angle using the encoders as feedback to ensure the robot turns evenly. Automatically stops at the specified turn angle.
Fc9-u16-icon.png - UINT Angle
Angle in degrees you wish to rotate. Range 1-65536
Fc9-comp-macro.png Forward
Drives both motors of the formula flowcode forwards with the power specified.
Fc9-comp-macro.png LCDWriteByte
Fc9-comp-macro.png BluetoothReceive
Attempt to read a byte from the Bluetooth receive queue.
Fc9-comp-macro.png LCDDrawLine
Draws a line on the LCD.
Fc9-u8-icon.png - BYTE X1
Range 0-127
Fc9-u8-icon.png - BYTE Y1
Range 0-31
Fc9-u8-icon.png - BYTE X2
Range 0-127
Fc9-u8-icon.png - BYTE Y2
Range 0-31
Fc9-comp-macro.png BluetoothQueueLength
Reads the length of received Bluetooth data in bytes.
Fc9-comp-macro.png BluetoothTransmitString
Sends a string via the Bluetooth data connection.
Fc9-comp-macro.png LCDBacklight
Controls the brighness of the LCD backlight
Fc9-u8-icon.png - BYTE Brightness
Range: 0-100, 0=Off, 1=Min Brightness, 100=Max Brightness
Fc9-comp-macro.png AudioReadFromBuffer
Allows the audio buffer to be used for other streaming data such as recording the mic.
Fc9-comp-macro.png ReadLineSensor
Reads the analogue value from the specified IR line sensor. Return value range: 0 to 4095 4095 represents the object is reflecting the most light.
Fc9-comp-macro.png LogoTurnRight
Rotates the robot right by a specific angle using the encoders as feedback to ensure the robot turns evenly. Automatically stops at the specified turn angle.
Fc9-comp-macro.png SpinRight
Spins the formula flowcode on the spot in a clockwise direction as seen from above.
Fc9-comp-macro.png CheckIR
Checks to see if a IR sensor is within the master threshold distance. Returns 0 if the IR reading is below the threshold. Returns 1 if the IR reading is greater than or equal to the threshold.
Range: 0 to 7 - 0=Left, 1=Front Left, 2=Front, 3=Front Right, 4=Right, 5=Rear Right, 6=Rear, 7=Rear Left
Fc9-comp-macro.png LCDPlotPixel
Allows a single pixel on the LCD to be set or cleared.
Sets the X coordinate - Range 0-127
Sets the Y coordinate - Range 0-31
Fc9-comp-macro.png LCDSetBackgroundColour
Sets the pixel colour to drive the LCD. Default colour is 1 where a set pixel is black and the background is white.
Fc9-u8-icon.png - BYTE Colour
Range 0-1 : 0=White, 1=Black
Fc9-comp-macro.png ReadIRSensor
Reads the analogue value from the specified IR distance sensor. Return value range: 0 to 4095 4095 represents the object is very close.
Fc9-comp-macro.png SetMotors
Sets the speed and direction of the Formula Allcode motors.
Fc9-s16-icon.png - INT Left
Valid Range = -100 to 100
Fc9-s16-icon.png - INT Right
Fc9-comp-macro.png LogoBackwards
Drives the robot backward using the encoders as feedback to ensure the robot drives straight. Automatically stops at the specified distance.
Fc9-u16-icon.png - UINT Distance
Distance you want to robot to drive in mm. Range 1-65535
Fc9-comp-macro.png EncoderReset
Resets the encoder counters to 0
Fc9-comp-macro.png Reverse
Drives both motors of the formula flowcode backwards with the power specified.
Fc9-comp-macro.png WaitForSwitch
Waits for the specified switch to be pressed.
Which switch do we want to wait for 0=Left, 1=Right, 2=Either, 3=Both
Fc9-comp-macro.png ReadLDR
Reads the current light level from the on board light sensor. Return value range: 0 to 4095 4095 represents the maximum level of light and 0 represents the minimal level of light.
Fc9-comp-macro.png LCDDrawRectangle
Draws a rectange on the LCD.
Range 0-127
Range 0-31
Range 0-127
Range 0-31
Sets the transparency of the box, 0=Box contains background colour, 1=Box contains previous pixel data
Fc9-u8-icon.png - BYTE Solid
Chooses to fill the box with colour, 0=Box contains transparency data, 1=Box contains foreground colour
Fc9-comp-macro.png EncoderReadCount
Reads one of the motor encoder counters. Each encoder count is equal to 0.314159 mm.
0 = LeftCount, 1=RightCount
Fc9-comp-macro.png CheckUSB
Checks to see if a USB cable is connected to the robot. Returns 0 for no connection and 1 for an active connection.
Fc9-comp-macro.png LCDSetForegroundColour
Fc9-comp-macro.png Initialise
Starts up the Formula Allcode PWM for motor control and performs the wait for button press if enabled.
Fc9-comp-macro.png LogoSetSpeed
Sets the cruise speed for LOGO type macros. Default speed 20%.
Fc9-u8-icon.png - BYTE Speed
Range 1-100, Default 60
Fc9-comp-macro.png LogoForwards
Drives the robot forward using the encoders as feedback to ensure the robot drives straight. Automatically stops at the specified distance.
Fc9-comp-macro.png LCDClear
Clears the contents of the graphical LCD.
Fc9-type-7-icon.png Wait For Button
Determines if the program will automatically wait for one of the front switches to be pressed before executing the program. Ran as part of the initialise function after the various components have been initialised.
Fc9-type-16-icon.png Show Creation Info
Specifies what information is shown to the user on calling the initialise function. The time and date shown are the compilation time and date to help pinpoint the firmware version.
Fc9-type-7-icon.png Bluetooth Reset
Decides if the Bluetooth data connection can reset the Formula AllCode. Used by mLoader when programming via Bluetooth to allow reprogramming without having to physically touch the robot. To ensure programming security set this option to No.
Fc9-type-7-icon.png Use Motor Feedback
Controls when the motor feedback is used. No - Speed control feedback is not used for SetMotors commands. Yes - Speed control feedback is used for the SetMotors commands. SetMotors commands include Forward, Backward, SpinLeft, SpinRight as well as SetMotors itself. Logo functions always use feedback.
Fc9-conn-icon.png IR Simulation
Fc9-type-16-icon.png IR Simulation Mode
Controls how the IR sensors are modelled in simulation. Linear is the legacy mode and works as it has always done. Exponential attempts to provide a more accurate reading which is closed to response of the real world hardware,
Fc9-conn-icon.png IR Thresholds (CheckIR macro)
Fc9-type-21-icon.png IR Distance
IR Threshold used with the CheckIR macro
Fc9-type-21-icon.png Line Sensitivity
Fc9-conn-icon.png Simulation Properties
Fc9-type-21-icon.png Sim Speed (1 - 100)
Sets the simulated amount of movement relative to the speed of the Formula Allcode.
Fc9-type-21-icon.png Timer Interval (ms)
Interval in milliseconds between each simulated movement of the Formula Allcode robot.
Fc9-type-16-icon.png Collision Method
Select which objects the robot sensors will interact with.
Fc9-type-17-icon.png Light Source
Panel object specified as the simulation light source. Used when simulating "find the light" type tasks.
Fc9-type-17-icon.png Addon Mechanics
Useful if you are creating add-ons to the robot which you want to be able to simulate. Point the property at the group containing the Formula Allcode and the additional mechanics. Otherwise leave blank to maintain the normal simulation functionality.
