Component: FTDI (FT800) (FT800) (Misc)
| Author | MatrixTSL |
| Version | 2.0 |
| Category | Misc |
FTDI (FT800) component
The FT800 provides a powerful feature set in a small package to create dynamic HMI interfaces. The device supports line by line graphics rendering to 1/16 of a pixel on displays with resolution up to 512 x 512 with 262K colours. The chip includes a touch controller for sensing touch feedback from a TFT display with a resistive touch panel as well as a sound synthesizer and audio playback with a PWM output to drive a speaker.
Please click here for the component source code: FC_Comp_Source_FTDI-FT800.fcfx
| MemRead16 | |
| Reads a single unsigned int from the FT800 internal address space | |
| Address | |
| MemRead8 | |
| Reads a single data byte from the FT800 internal address space | |
| Address | |
| MemRead32 | |
| Reads a single unsigned long from the FT800 internal address space | |
| Address | |
| MemWrite16 | |
| Writes a unsigned int value to the FT800 internal address space | |
| Address | |
| Data | |
| MemWrite8 | |
| Writes a byte value to the FT800 internal address space | |
| Address | |
| Data | |
| CommandWrite | |
| Sends FT800 command | |
| Command | |
| MemWrite32 | |
| Writes a unsigned long value to the FT800 internal address space | |
| Address | |
| Data | |
| System initialization routines. Executed once on reset. Returns 0 if device not detected or 1 if device is correctly initialised. | |
