| Author
Matrix Ltd
| Version
1.4
| Category
Graphical Monochrome
GLCD (KS0108) component
Graphical display component designed to work with the KS0108 type monochrome displays. Also compatible with the newer S6A0107 controller IC displays.
Please click here for the component source code: FC_Comp_Source_GLCD_KS0108.fcfx
ReadFontWidth
- BYTE
Font
- BYTE
Character
- BYTE
SetFontScaler
- BYTE
ScaleX
- BYTE
ScaleY
- INT
Number
- UINT
X
- UINT
Y
- BYTE
Font
- BYTE
Transparent
DrawLine
- UINT
X1
- UINT
Y1
- UINT
X2
- UINT
Y2
DrawEllipse
- UINT
X
- UINT
Y
- UINT
XRadius
- UINT
YRadius
- BYTE
Transparent
- BYTE
Solid
Plot
- UINT
X1
- UINT
Y1
SetDisplayOrientation
- BYTE
Orientation
BPlot
- UINT
X1
- UINT
Y1
ReadFontStat
- BYTE
Font
- BYTE
Index
| 0=SpaceWidth, 1=PixelHeight
- BYTE
Print
- STRING
Str
- UINT
X1
- UINT
Y1
- BYTE
Font
- BYTE
Transparent
ClearDisplay
SetBackgroundColour
| Specifies the colour of the background.
- BYTE
Pixel_Colour
| 0=White, 1=Black
DrawCircle
- UINT
X
- UINT
Y
- UINT
Radius
- BYTE
Transparent
- BYTE
Solid
SetForegroundColour
| Specifies the colour of the foreground.
- BYTE
Pixel_Colour
| 0=White, 1=Black
DrawRectangle
- UINT
X1
- UINT
Y1
- UINT
X2
- UINT
Y2
- BYTE
Transparent
- BYTE
Solid
Dimensions
Pixel Width
Pixel Height
Controller Count
| Speicifies the number of controller IC's built into the display and therefore the number of available chip select pins
Colour
Monochrome
Foreground Color
Background Colour
Bit Depth
Color Bit Depth
Red Bit Depth
Green Bit Depth
Blue Bit Depth
CS1
| Chip select to address the first controller IC
CS2
| Chip select to address the second controller IC
RS
| Data / Instruction register select pin.
RW
| Read / write select pin
Enable
| Data enable to clock a command or data in or out of the device
Data0
| Data Pin 0
Data1
| Data Pin 1
Data2
| Data Pin 2
Data3
| Data Pin 3
Data4
| Data Pin 4
Data5
| Data Pin 5
Data6
| Data Pin 6
Data7
| Data Pin 7
Reset
| Display reset pin
Fonts
Font Count
Font 0
Font
Character Spacing
Space Width
Component Label
Component Label Scale
Physical Orientation
Display Delay
Enable Delay
| Time in micro seconds to wait before and after toggling the enable pin.
