Component: LED Free (Generic) ()
Revision as of 14:12, 20 January 2023 by Wiki bot (talk | contribs)
Version 0.1
Category
LED Free (Generic) component
Basic LED component using simple geometric shapes.
Please click here for the component source code: FC_Comp_Source_LED_Shape_Free.fcfx
Pin
Chip pin to connect the LED to. NB) LED will not change state unless there is a pin connection.
Polarity
Active High: Pin true -> On color, Pin false -> Off color. Active Low: Pin true -> Off color, Pin false -> On color.
On Color
The color that the LED will take when lit. The off colour is calculated automatically to be a darker shade of the same hue.
Shape
Shape of the LED.
Size
Width
Width of the LED shape.
Height
Height of the LED shape.
Depth
Depth of the LED shape.
Show
Decide what labels to show... None - no labels are displayed Name - shows each component's name Property - shows a particular property of each component (see 'property' below.
Property
Show a particular property of each object. If a port or pin property is chosen, the label can be abbreviated to remove the '$PORT' text.
Color
Color of the labels text.
Scale
Sets the basic size (text height) of the labels.
Follow Zoom
Whether labels get bigger and smaller when the panel is zoomed in and out.
Position
Set the position of the label relative to the component.
