Component: Light Sensor (Grove 101020132) (101020132) (Light)
Revision as of 14:12, 20 January 2023 by Wiki bot (talk | contribs)
Category Light
Light Sensor (Grove 101020132) component
The Light sensor module is a simple analogue photo transistor. Used to detect the intensity of the indoor light.
Please click here for the component source code: FC_Comp_Source_Light_Sensor.fcfx
GetString
Reads the ADC as a direct voltage and returns as as tring
- STRING Return
GetAverageByte
Function call to read the ADC as a byte average sample over time
- BYTE NumSamples
- BYTE DelayUs
Number of micro seconds in between taking each sample
GetAverageInt
Function call to read the ADC as a full width average sample over time
- BYTE NumSamples
- BYTE DelayUs
GetVoltage
- FLOAT Return
GetInt
Blocking call to read the ADC at full bit depth
GetByte
Blocking call to read the ADC as a byte
Settings
VRef voltage
VRef option
Conversion speed
Aquisition cycles
Bit Depth
