Component: Photo Reflector (Light)
Revision as of 14:12, 20 January 2023 by Wiki bot (talk | contribs)
Category Light
Photo Reflector component
Uses InfraRed light to detect if an external object is near to the sensor. Returns a discrete analogue signal which can represent distance from the nearest object. Useful for applications like wall following, control based systems and robotics.
Please click here for the component source code: FC_Comp_Source_PhotoReflector.fcfx
SampleSensor
Samples the sensor and automatically controls the emitter pin if enabled. Returns the analogue reading from the sensor pin.
Sets up the I/O to allow the sensor to operate.
Emitter Type
Decides if the emitter needs to be switched on and off during sampling
Sense Pin
Pin connected to the sensor element of the photo transistor
Discrete Distance
Simulation range used to determine if the sense pin is active or not.
