Component: Robot Arm v2 (AllCode)
Revision as of 14:13, 20 January 2023 by Wiki bot (talk | contribs)
Category AllCode
Robot Arm v2 component
Drives the Matrix Robot Arm v2 hardware via the AllCode API. Allows connections via USB, Bluetooth and WIFI.
Please click here for the component source code: FC_Comp_Source_RA2_ComponentSource.fcsx
Fc9-comp-macro.png SetWIFIPort
Sets the WIFI port number
Fc9-u16-icon.png - UINT Port
Default 1245
Fc9-comp-macro.png WhileMoving
Blocking call that waits up to 10 seconds for the current movement operation to complete. Returns when complete. Return of 1 indicates movement complete, 0 indicates timeout.
Fc9-comp-macro.png SetWIFIPassword
Configures the WIFI Password string and stores into the none volatie memory onboard the robot arm. Call the SetWifiMode macro after this to action the change.
Fc9-string-icon.png - STRING Password
Password String, Max 32 Characters
Fc9-comp-macro.png SetCalibrationLengths
Sets the lengths of parameters A and D used as part of the kinematics calculations to get and set the angles using XYZ coordinates
Fc9-f32-icon.png - FLOAT LengthA
Fc9-f32-icon.png - FLOAT LengthD
Fc9-comp-macro.png SetMovementSpeed
Controls the movement speed of the arm and the ramping increment
Fc9-u16-icon.png - UINT Speed
Range 0-10000 default 8000
Fc9-u16-icon.png - UINT Increment
Range 0 to 5000, default 50
Fc9-comp-macro.png GetPLCInputs
Reads the inputs on the secondary grove connector used to connect to outputs from a connected PLC or other external switch.
Fc9-comp-macro.png SetGripper
Sets the new position of the gripper
Fc9-u8-icon.png - BYTE Position
0 = Closed, 255 = Fully Open
Fc9-comp-macro.png SetCalibrationPosition
Called when the arm gripper is in the calibration position of X0 Y300 Z5 Reconfigures the kinematics calculations based on this. Performed in factory to calibrate the arm, warning calling this function will effect factory calibration.
Fc9-comp-macro.png StoreAngles
Stores the specified joint angles into an internal none volatile memory location.
Fc9-u8-icon.png - BYTE PositionIndex
Range: 0 to 40
Fc9-f32-icon.png - FLOAT AngleA
Range 0.0 to 359.0
Fc9-f32-icon.png - FLOAT AngleB
Range 0.0 to 359.0
Fc9-f32-icon.png - FLOAT AngleC
Range 0.0 to 359.0
Fc9-comp-macro.png GetWifiIP
Collects the IP address of the robot arm WIFI connection.
Fc9-comp-macro.png GetColourSensor
Samples and returns the RGB values read by the colour sensor
Fc9-u8-icon.png - BYTE RGB
Byte Array To Hold the RGB sensor values
Fc9-comp-macro.png SetMotor
Sets the step position of a single motor
Fc9-u8-icon.png - BYTE Motor
0=A, 1=B, 2=C
Fc9-u16-icon.png - UINT Position
Fc9-comp-macro.png ResetToBoot
Resets the board into bootload mode for reprogramming. Comms port will be closed on calling this macro,
Fc9-comp-macro.png IsMoving
Checks to see if the robot arm or gripper is moving. Returns 0 if the arm is not moving and 1 if the arm is still in transit.
Fc9-comp-macro.png SetAngle
Sets the angle of a single motor
0=A, 1=B, 2=C
Range 0.0 to 359.0
Fc9-comp-macro.png SetXYZ
Moves the machine so that the end tool is in the specified XYZ position. Returns 1 if the coordinates are within range of the Arm else returns 0.
Fc9-s16-icon.png - INT X
Fc9-s16-icon.png - INT Y
Fc9-s16-icon.png - INT Z
Fc9-comp-macro.png SetBluetoothPin
Configures the Bluetooth pin and stores into the none volatie memory onboard the robot arm. Call the SetBluetoothMode macro after this to action the change.
Fc9-string-icon.png - STRING Pin
Pin String, 4 Numeric Characters e.g. "1234"
Fc9-comp-macro.png HomeAll
Function to automatically home all motors. Macro blocks until complete.
Fc9-comp-macro.png SetRelay
Allows the vacuum relay to be switched on and off.
Fc9-bool-icon.png - BOOL State
Fc9-comp-macro.png SetCalibrationRadius
Fc9-f32-icon.png - FLOAT Radius
Fc9-comp-macro.png SetAngles
Sets the angle of all motors
Range 0.0 to 359.0
Range 0.0 to 359.0
Range 0.0 to 359.0
Fc9-comp-macro.png GotoPosition
Recalls a position from the selected internal none volatile memory location. Performs linear interpolated movement to the selected position.
Range: 0 to 40
Fc9-comp-macro.png SetWifiMode
Configures the WIFI mode. When enabled the robot arm can either create its own WIFI network or join an existing WIFI network,
Fc9-u8-icon.png - BYTE Mode
0=Disabled, 1=Host Network, 2=Join Network
Fc9-comp-macro.png HomeAxis
Function to automatically home a specific motor. Macro blocks until complete.
Fc9-u8-icon.png - BYTE Axis
0=A, 1=B, 2=C
Fc9-comp-macro.png GetAngles
Collects the current joint angles of the motors.
Fc9-f32-icon.png - FLOAT Angles
Float Array To Hold the step position return values
Fc9-comp-macro.png DisableMotors
Disables all motors
Fc9-comp-macro.png StoreMotors
Stores the specified step position into an internal none volatile memory location.
Range: 0 to 40
Fc9-u16-icon.png - UINT PositionA
Fc9-u16-icon.png - UINT PositionB
Fc9-u16-icon.png - UINT PositionC
Fc9-comp-macro.png SetCanId
Stores the specified CAN ID into an internal none volatile memory location.
Fc9-u16-icon.png - UINT ID
Fc9-comp-macro.png GetAPI
Gets the API version number
Fc9-comp-macro.png SetMotors
Sets the step position of all motors
Fc9-comp-macro.png SetCanMode
Configures the CAN mode.
Fc9-bool-icon.png - BOOL Mode
0=Disabled, 1=Enabled
Fc9-comp-macro.png SetWifiSSID
Configures the WIFI SSID string and stores into the none volatie memory onboard the robot arm. Call the SetWifiMode macro after this to action the change.
Fc9-string-icon.png - STRING SSID
Netword ID String, Max 32 Characters
Fc9-comp-macro.png GetPosition
Collects the current step positions of the motors.
Fc9-u16-icon.png - UINT Positions
UINT Array To Hold the step position return values
Fc9-comp-macro.png StoreCurrentPosition
Stores the current position into an internal none volatile memory location.
Range: 0 to 40
Fc9-comp-macro.png GetXYZ
Collects the current XYZ position of the end tool.
Fc9-s16-icon.png - INT XYZ
INT Array To Hold the X, Y and Z return values
Fc9-comp-macro.png SetBluetoothMode
Configures the Bluetooth mode.
Fc9-comp-macro.png Initialise
Fc9-comp-macro.png SetBluetoothName
Configures the Bluetooth device name and stores into the none volatie memory onboard the robot arm. Call the SetBluetoothMode macro after this to action the change.
Fc9-string-icon.png - STRING Name
Bluetooth Device String, Max 20 Characters
Fc9-type-16-icon.png Simulation Mode
Fc9-conn-icon.png API Settings
Fc9-type-16-icon.png Comms Method
Selects the method to communicate with the Matrix 3 Axis Robot Arm. USB connection requires the USB drivers to be installed. Bluetooth connection requires the device first be paired using the Windows Bluetooth control panel. WIFI connection requires the connection settings to be configured first on the robot using USB or Bluetooth. CAN connection does not simulate and works on embedded hardware e.g. the MIAC.
Fc9-conn-icon.png COM Port Settings
Fc9-type-7-icon.png Autodetect
Autodetects the COM port, only works for USB AllCode connection.
