Component: USB Speaker (Misc)
Revision as of 14:13, 20 January 2023 by Wiki bot (talk | contribs)
Author Matrix Ltd.
Version 1.3
Category Misc
USB Speaker component
Component to create a USB System Speaker. Compatible with USB enabled microcontroller devices. Currently only compatible with the 16-bit PIC range of devices.
Please click here for the component source code: FC_Comp_Source_USBSpeaker.fcfx
IsPlaybackEnabled
UsbRx
Receives the data from the USB connection
ReadData
Reads a single 16-bit data value from the audio buffer
Starts up the USB communications and attempts to enumerate. Returns 0 for a successful startup or 255 for a enumeration timeout.
USB Properties
Vendor ID
USB VID
Product ID
USB PID
Device Name
USB Device Name
Manufacturer
USB Manufacturer
Major Version
USB Major Version Number
Minor Version
USB Minor Version Number
Sample Rate
Enumeration Timeout
Specifies if the enumeration (Initialise function) can timeout if taking too long.
Text displayed on the I/O flasher comms component.
