Component: Ultrasonic Ranger (Grove 101020010) (101020010) (Audio)
Revision as of 14:13, 20 January 2023 by Wiki bot (talk | contribs)
Category Audio
Ultrasonic Ranger (Grove 101020010) component
The ultrasonic sensor is a non-contact distance measurement module. It's designed for easy modular project usage with industrial performance. Detecting range: 3cm to 4m, best in 30 degree angle.
Please click here for the component source code: FC_Comp_Source_Ultrasonic_Ranger.fcfx
This example performs an ultrasonic range sample and then converts the sample from a timing into a measurement in millimetres.
UltraSound Test
WaitForEcho
Waits until the echo has been received from the Ping macro allowing you to perform your own timing.
MeasureDistance
Converts a micro second time from the ultrasonic range sensor and returns the range in mm, cm or inches.
- UINT TimeDelay
Microsecond reading from Ultrasound module
- BYTE Scale
0=MM / 1=CM / 2=Inch
Ping
Performs a transmit ping allowing you to monitor the incoming signal and perform your own timings maybe using a rising edge interrupt and a timer.
SampleSensor
Sends out an ultrasonic ping and times how long it takes to receive the echo. Returns the time in microseconds. Performs the timing using software so depending on the speed of the micro will be an approximation. For better results use the Ping macro.
Control Pin
Pin connected to the emitter of the sensor.
Measurement
Time Measurement
Controls how the sensors ultrasonic ping is timed, Either using single microsecond delays or using timer hardware. On slower devices e.g. PIC it is advisable to use the Timer method.
Timer Properties
Timer
Timer Peripheral to use to monitor the passage of time.
Discrete Distance
Simulation range used to determine if the sense pin is active or not.
