Component: FCD helper (Matrix Tools)
Revision as of 14:14, 20 January 2023 by Wiki bot (talk | contribs)
Category Matrix Tools
FCD helper component
A helper control to query the current Flowcode definition XML file.
Please click here for the component source code: FC_Comp_Source_fcdhelper.fcfx
GetStrListItem
Gets a list item from a string index and a textual name Suitable for writing to a property filter Newline is added
- STRING Index
- STRING Name
- STRING Return
GetIntListItem
Gets a list item from an integer and a textual name Suitable for writing to a property filter Newline is added
- UINT Index
- STRING Name
- STRING Return
Register
Registers a property to update when the FCD changes
- HANDLE Dest
- STRING PropName
- STRING FCDPath
- UINT INdex
A zero based index of the path to find
- STRING IxAttr
- STRING NameAttr
GetPropertyList
Gets a filter list suitable for adding to a property Uses the [u]IxName[/u] as the index into the list Uses the [u]Text[/u] as the line to show in list-boxes
- STRING FCDPath
- UINT Index
- STRING IxName
- STRING Text
- STRING Return
