Component: Nextion Display (Graphical Color)
Revision as of 15:12, 20 January 2023 by Wiki bot (talk | contribs)
Category Graphical Color
Nextion Display component
A simple libray to interface a Nextion display. The elements on the nextion display are built using the Nextion Editor software and uploaded to the display. The component can then interact with the display elements.
Please click here to view the component source code (Beta): FC_Comp_Source_API_Display_Nextion.fcfx
Handling Buttons
This example looks for button presses with IDs 1 and 2. On a button release event the corresponding LEDs will be toggled.
Nextion Touch Demo
GetTouchID
Gets the ID of the corresponding touch event. Must be called after calling GetTouchEvent component macro.
GetValue
Gets the value from a specific item
- STRING Name
- ULONG Return
SetText
Sets the text of a specific item
- STRING Name
- STRING Text
GetText
Gets the text of a specific item
- STRING Name
- STRING Return
SetFontColour
Sets the foreground font colour of a specific item
- STRING Name
- ULONG Colour
SetPage
Sets the page of the display allowing multiple configurations
- STRING Name
Name of the page e.g. "page0"
SetValue
Sets the numeric value of a specific item
- STRING Name
- ULONG Number
GetTouchEvent
Collects the next touch event in the queue. Returns 0 for no touch event detected, 1= touch press, 2 = touch release
SetBackgroundColour
Sets the background colour of a specific item
- STRING Name
- ULONG Colour
Sets up the UART connection to the Nextion display
Communications
Baud Options
TX
RX
Touch Queue Size
Number of touch press/release events we can store before running out of memory.
Receive Buffer Size
Sets the number of byte elements inside the circular buffer.
Timeout
Time in milliseconds to wait for a reply to a command.
Data Source
Simulation data source used to allow the component to connect to various remote devices Nothing - Simulation data is ignored COM port - Routes the communication data to and from a physical or virtual COM port API - Routes the communication data via a data injector component on the Panel.
GetTouchID
GetValue
- STRING Name
- ULONG Return
SetText
- STRING Name
- STRING Text
GetText
- STRING Name
- STRING Return
SetFontColour
- STRING Name
- ULONG Colour
SetPage
- STRING Name
SetValue
- STRING Name
- ULONG Number
GetTouchEvent
SetBackgroundColour
- STRING Name
- ULONG Colour
Communications
Baud Options
TX
RX
Touch Queue Size
Receive Buffer Size
Timeout
Data Source
