| Author
Matrix TSL
| Version
1.0
| Category
AllCode
Control component
Drives the Matrix Control hardware via the AllCode API.
Please click here to view the component source code (Beta): FC_Comp_Source_Control_ComponentSource.fcsx
SetAutoPrescaler
| Configures the automatic mode prescaler, for running really slowly. Defaults off so no need to call this unless you are using it.
- BYTE
Prescaler
| 0=Off, 2=Div by 2, 3=Div By 3 etc
GetOutput
| Gets the output value as an integer value betwen 0 and 100 representing the output PWM duty
- BYTE
SetAutoOnOff
| Enable the auto PID control using the on-board microcontroller
- BYTE
| Range: 0-1
- BYTE
Enable
| 0=Off, 1=5Hz, 2=10Hz, 3=20Hz, 4=50Hz, 5=100Hz, 6=200Hz, 7=500Hz, 8=1KHz
SetWIFIPort
| Configures the WIFI Port number. Default 1245.
- UINT
Port
| Default 1245
SetAutoPIDFlip
| Controls if the PID response is flipped, a negative response vs a positive
- BOOL
Flip
| Default: 0=Not Flipped, 1=Flipped
SetBluetoothDetails
| Configures the Bluetooth device name and pin and stores into the none volatie memory onboard the robot arm. Call the SetBluetoothMode macro after this to action the change.
- STRING
Name
| Bluetooth Device String, Max 20 Characters
- STRING
Pin
| Pin String, 4 Numeric Characters e.g. "1234"
GetDataArray
| Collects a data array from the Control board. Returns number of samples collected.
- FLOAT
data
- BYTE
GetWifiIP
| Collects the IP address of the robot arm WIFI connection.
- STRING
SetWifiDetails
| Configures the WIFI SSID and Password strings and stores into the none volatie memory onboard the robot arm. Call the SetWifiMode macro after this to action the change.
- STRING
SSID
| Netword ID String, Max 32 Characters
- STRING
Password
| Password String, Max 32 Characters
ResetToBoot
| Resets the board into bootload mode for reprogramming. Comms port will be closed on calling this macro,
SetAutoOnOffParam
| Sets the Hysteresis parameter for the Auto on-board On/Off
- FLOAT
Hysteresis
| Hysterists in real world units
SetWifiMode
| Configures the WIFI mode. When enabled the control system can either create its own WIFI network or join an existing WIFI network,
- BYTE
Mode
| 0=Disabled, 1=Host Network, 2=Join Network
GetPIDComponent
| Gets one of the PID controller output components in real world units
- BYTE
Index
| Range 0-2, 0=P, 1=I, 2=D
- FLOAT
SetEthernetPort
| Configures the Ethernet Port number. Default 1245.
- UINT
Port
| Default 1245
SetEthernetIP
| Configures the Ethernet IP Address.
- STRING
IP
| IP Address string e.g. "192.168.1.100"
SetCANID
| Stores the specified CAN ID into an internal none volatile memory location.
- UINT
ID
GetFeedback
| Gets the feedback as a value in real world units
- FLOAT
GetAPI
| Gets the API version number
- BYTE
SetManualDuty
| Sets duty parameter for one of the manual controlled outputs
- BYTE
| Range: 0-1
- FLOAT
Duty
| Duty Cycle Output in Percentage Range 0 - 100%
CheckErrorStatus
| Returns the Error status value indicating if there has been any errors. 0 = No Error 1 = Timeout Error
- BYTE
SetCANMode
| Configures if the CAN API mde is enabled or disabled.
- BYTE
Mode
| 0=Disabled / 1=Enabled
SetAutoPID
- BYTE
| Range: 0-1
- BYTE
Enable
SetLogDivider
| Configures the rate of the PID logging.
- BYTE
Divider
| Divides the rate by the selected value
ZeroSensor
| Zeros the attached sensor reading. Useful for Pressure and Level control applications.
SetAutoPIDParam
| Sets one of the P, I, D parameters for the Auto on-board PID
- BYTE
Index
| Range: 0-5 Where 0=P, 1=I, 2=D, 3=IntClamp, 4=DFilt, 5=FiltCo
- FLOAT
Value
| Range: 0.0 to 65.535
SetEthernetMode
| Configures the Ethernet mode.
- BYTE
Mode
| 0=Disabled, 1=Enabled
SetBluetoothMode
| Configures the Bluetooth mode.
- BOOL
Mode
SetFeedbackMethod
| Sets feedback method to dictate which control application we are running
- BYTE
FBMethod
| Range: 0-3 Where 0=Level, 1=Flow, 2=Pressure, 3=Temp
- FLOAT
InputScaler
| Feedback scaling factor used to convert the feedback reading into a meaningful value
- FLOAT
OutputScaler
| Value used to convert input to 0-100% duty
SetSetpoint
| Sets Setpoint parameter for the Auto on-board PID
- FLOAT
Setpoint
| Required Output in Real World Units
Comms Method
| Selects the method to communicate with the Matrix 3 Axis Robot Arm. USB connection requires the USB drivers to be installed. Bluetooth connection requires the device first be paired using the Windows Bluetooth control panel. WIFI connection requires the connection settings to be configured first on the robot using USB or Bluetooth. CAN connection does not simulate and works on embedded hardware e.g. the MIAC.
COM Port Settings
Autodetect
| Autodetects the COM port, only works for USB AllCode connection.
COM Port
| Selects which port to communicate with, only lists ports which are currently available.
Text Colour
SetAutoPrescaler
- BYTE
Prescaler
GetOutput
- BYTE
SetAutoOnOff
- BYTE
| Range: 0-1
- BYTE
Enable
SetWIFIPort
- UINT
Port
| Default 1245
SetAutoPIDFlip
- BOOL
Flip
SetBluetoothDetails
- STRING
Name
- STRING
Pin
GetDataArray
- FLOAT
data
- BYTE
GetWifiIP
- STRING
SetWifiDetails
- STRING
SSID
- STRING
Password
ResetToBoot
SetAutoOnOffParam
- FLOAT
Hysteresis
SetWifiMode
- BYTE
Mode
GetPIDComponent
- BYTE
Index
- FLOAT
SetEthernetPort
- UINT
Port
| Default 1245
SetEthernetIP
- STRING
IP
SetCANID
- UINT
ID
GetFeedback
- FLOAT
GetAPI
- BYTE
SetManualDuty
- BYTE
| Range: 0-1
- FLOAT
Duty
CheckErrorStatus
- BYTE
SetCANMode
- BYTE
Mode
SetAutoPID
- BYTE
| Range: 0-1
- BYTE
Enable
SetLogDivider
- BYTE
Divider
ZeroSensor
SetAutoPIDParam
- BYTE
Index
- FLOAT
Value
SetEthernetMode
- BYTE
Mode
SetBluetoothMode
- BOOL
Mode
SetFeedbackMethod
- BYTE
FBMethod
- FLOAT
InputScaler
- FLOAT
OutputScaler
SetSetpoint
- FLOAT
Setpoint
Comms Method
COM Port Settings
Autodetect
COM Port
Text Colour
