Component: Input Digital (DSP Inputs)
Revision as of 15:13, 20 January 2023 by Wiki bot (talk | contribs)
Version 1.2
Category DSP Inputs
Input Digital component
Allows the values from a buffer to be assigned. Either a value at a time or from an array. The input signal would usually take the form of an ADC reading or raw data values.
Please click here to view the component source code (Beta): FC_Comp_Source_DSP_Input.fcfx
Here is a basic example demonstrating how to pass a value into the DSP chain. Delay The input value in the example uses an ADC reading but this can be taken from anything such as a reading from a CSV file on a SD card or a value passed by a sensor on a I2C bus etc.
AddByte
Adds a single byte value to the current location in the specified buffer. Auto increments current location if output buffer size is greater than 1.
- BYTE Data
AddFloatArray
Adds an array of float values to the current location in the specified buffer. Auto increments current location if output buffer size is greater than 1.
- FLOAT Data
- UINT Count
AddByteArray
Adds an array of byte values to the current location in the specified buffer. Auto increments current location if output buffer size is greater than 1.
- BYTE Data
- UINT Count
AddLong
Adds a single long value to the current location in the specified buffer. Auto increments current location if output buffer size is greater than 1.
- ULONG Data
AddInt
Adds a single integer value to the current location in the specified buffer. Auto increments current location if output buffer size is greater than 1.
- UINT Data
AddLongArray
Adds an array of long values to the current location in the specified buffer. Auto increments current location if output buffer size is greater than 1.
- ULONG Data
- UINT Count
AddIntArray
Adds an array of integer values to the current location in the specified buffer. Auto increments current location if output buffer size is greater than 1.
- UINT Data
- UINT Count
AddFloat
Adds a single float value to the current location in the specified buffer. Auto increments current location if output buffer size is greater than 1.
- FLOAT Data
Buffer Size
Buffer Type
Sets the buffer data type, data is automatically scaled to fit and make full use of the data type.
AddByte
- BYTE Data
AddFloatArray
- FLOAT Data
- UINT Count
AddByteArray
- BYTE Data
- UINT Count
AddLong
- ULONG Data
AddInt
- UINT Data
AddLongArray
- ULONG Data
- UINT Count
AddIntArray
- UINT Data
- UINT Count
AddFloat
- FLOAT Data
Buffer Size
Buffer Type
