Component: Dashboard lamp ()
Revision as of 15:13, 20 January 2023 by Wiki bot (talk | contribs)
Author Matrix
Version 1.1
Category
Dashboard lamp component
Indicator with bezel and label, particularly suitable for viewing on the dashboard. Indicator on/off colors, bezel color and label all editable via properties.
Please click here to view the component source code (Beta): FC_Comp_Source_Dashboard_Indicator.fcfx
LED Resistor Calculator Tool
Pin
Chip pin to connect the LED to.
Polarity
Active High: Pin true -> On color, Pin false -> Off color Active Low: Pin true -> Off color, Pin false -> On color
On Color
The color of the indicator when it is turned on.
Off Color
The color of the indicator when it is turned off.
Bezel Color
Color of the bezel.
Label Color
Color of the label text.
Text
Text to show as the component label.
Font
Font for the label text.
Pin
Polarity
On Color
Off Color
Bezel Color
Color of the bezel.
Label Color
Text
Font
