Component: Bluetooth (BL0170) (E-blocks 2)
| Author | Matrix Ltd. |
| Version | 1.3 |
| Category | E-blocks 2 |
Bluetooth component
Low level routines for controlling a Microchip RN4677 Bluetooth Module. Also available in the form of the BL0170 Bluetooth E-block. Uses an interrupt to receive characters from the UART and improve reliability, Must be used with a hardware UART channel.
Please click here to view the component source code (Beta): FC_Comp_Source_EBlocks2_Bluetooth_RN4677_BL0170.fcfx
| SendString | |
| Sends a string to the Bluetooth module. | |
| Command | |
| SendCR | |
| LeaveCommandMode | |
| Leaves command mode allowing data to be passed back and forth, | |
| ConnectToMAC | |
| Connects to a specific Bluetooth MAC address. Waits up to 5 seconds for connection to be established. Returns 1 if connection was successful. | |
| MACAddress | |
| ReceiveCount | |
| Returns the number of bytes currently sat waiting in the receive buffer. | |
| ReadString | |
| Copies the incoming data from the data string array to a local string variable. | |
| NumBytes | |
| Maximum number of bytes to try and read | |
| SendByte | |
| Sends a single data byte out to the Bluetooth module. | |
| Data | |
| EnterCommandMode | |
| Enters command mode allowing commands to be sent using the SendCommand macro. Returns: 0 = No Reply / 1 = Command Mode OK | |
| GetMACAddress | |
| Gets the local Bluetooth device MAC address. | |
| Sets up the Bluetooth module including: - Enabling the UART - Configuring the module (Name / Key / etc) Returns 1 for OK and 0 for no reply. | |
| SendString | |
| Command | |
| SendCR | |
| ConnectToMAC | |
| MACAddress | |
| ReceiveCount | |
| ReadString | |
| NumBytes | |
| SendByte | |
| Data | |
| GetMACAddress | |
