Component: API (ESP32) (API Slave Devices)
Author | Matrix TSL |
Version | 2.0 |
Category | API Slave Devices |
API (ESP32) component
Connects to an ESP32 device running the API Firmware allowing the board to become a slave to the Flowcode Embedded simulation or Flowcode App Developer. Supports: Digital IO / ADC / I2C / SPI / PWM / UART See Flowcode Help Wiki for firmware.
Please click here to view the component source code (Beta): FC_Comp_Source_ESP32_API_Comp.fcfx
The App Developer (ESP32) component allows an ESP32 board to be controlled from within the Flowcode simulation runtime.
To allow Flowcode to communicate and control the ESP32 hardware the board must first be pre-programmed with dedicated firmware.
The firmware source project can be downloaded from here.
You will need to set your WIFI SSID and Password near the top of Main to allow the ESP module to connect to your network.
The IP Address to the ESP32 hardware is selected via the SCADA_ESP32 component IP Address property.
When building the component into a App Developer project remember to expose the IP Address property to allow the end user to select the address for the hardware.
- fixed statistics showing IO / ADC inputs / PWM
- scrolling log showing all commands and returns
Pin Mapping
Please note pins 34, 35, 36, 39 are only capable of digital inputs and cannot be used as digital outputs.
App Developer Slave Digital Pin | 0 | 1 | 2 | 3 | 4 | 5 | 6 | 7 | 8 | 9 | 10 | 11 | 12 | 13 | 14 | 15 | 16 | 17 | 18 | 19 | 21 | 22 | 23 | 25 | 26 | 27 | 32 | 33 | 34 | 35 | 36 | 39 |
Device Port Pin | A0 | A1 | A2 | A3 | A4 | A5 | A6 | A7 | A8 | A9 | A10 | A11 | A12 | A13 | A14 | A15 | A16 | A17 | A18 | A19 | A21 | A22 | A23 | A25 | A26 | A27 | B0 | B1 | B2 | B3 | B4 | B7 |
GPIO Number | 0 | 1 | 2 | 3 | 4 | 5 | 6 | 7 | 8 | 9 | 10 | 11 | 12 | 13 | 14 | 15 | 16 | 17 | 18 | 19 | 21 | 22 | 23 | 25 | 26 | 27 | 32 | 33 | 34 | 35 | 36 | 39 |
Please note not all analogue input pins are available as peripheral ADC2 is not accesible when WIFI/Bluetooth is active. Only the pins shown are available.
App Developer Slave Analogue Pin | 0 | 3 | 4 | 5 | 6 | 7 |
Device Port Pin | B4 | B7 | B0 | B1 | B2 | B3 |
GPIO Number | 36 | 39 | 32 | 33 | 34 | 35 |
Please note that PWM channels are tied in pairs and so channel 0 and 1 use the same internal timer peripheral. They will always run at the same frequency and when enabling channel 1 channel 0 duty will be reset to 0% and visa versa.
App Developer Slave Peripheral Pin | I2C 0 SDA | I2C 0 SCL | I2C 1 SDA | I2C 1 SCL | SPI 0 MOSI | SPI 0 MISO | SPI 0 SCK | SPI 1 MOSI | SPI 1 MISO | SPI 1 SCK | UART 0 RX | UART 0 TX | UART 1 RX | UART 1 TX | PWM 0 | PWM 1 | PWM 2 | PWM 3 | PWM 4 | PWM 5 | PWM 6 | PWM 7 | PWM 8 | PWM 9 | PWM 10 | PWM 11 | OneWire |
Device Port Pin | A13 | A12 | A15 | A14 | A9 | A10 | A11 | A6 | A7 | A8 | A26 | A25 | B0 | B1 | A0 | A2 | A4 | A5 | A12 | A13 | A14 | A15 | A16 | A17 | A18 | A19 | A21 |
GPIO Number | 13 | 12 | 15 | 14 | 9 | 10 | 11 | 6 | 7 | 8 | 26 | 25 | 32 | 33 | 0 | 2 | 4 | 5 | 12 | 13 | 14 | 15 | 16 | 17 | 18 | 19 | 21 |
PortA = GPIO pins 0 - 31 : A0 = GPIO 0
PortB = GPIO pins 32 - 39 : B0 = GPIO 32
I2CInitialise |
Initialise the I2C module ready for communications | |
Channel |
Channel Index: Range 0 - I2C Bus Count - 1 | |
Baud |
0=100KHz, 1=400KHz, 2=1MHz | |
Return |
IOGetInputPin |
Sets the selected digital pin to an input and reads the input state. | |
Pin |
Range: 0-29 | |
Return |
OneWireInitialise |
Initialise the OneWire module ready for communications | |
Channel |
Return |
ADCSample8 |
Reads the voltage present on an Analog pin as an 8-bit value range 0-255 | |
ADCChannel |
Range: 0, 3-7 | |
Return |
UARTInitialise |
Initialise the UART module ready for communications | |
Channel |
Channel Index: Range 0 - UART Bus Count - 1 | |
Return |
UARTCheckRX |
Check to see if the UART module has received any data | |
Channel |
Return |
OneWireTransmitByte |
Transmit a byte to the one wire bus a bit at a time | |
Channel |
Data |
Return |
I2CRestart |
Put the I2C Module into Restart mode | |
Channel |
Return |
PWMDisable |
Disable a PWM output | |
Channel |
Range: 0-11 | |
Return |
I2CStart |
Put the I2C Module into Start mode | |
Channel |
Return |
SPITransfer |
Transfer a byte using the SPI bus | |
Channel |
Channel Index: Range 0 - SPI Bus Count - 1 | |
DataOut |
Return |
I2CReceive |
Receive a byte using the I2C bus | |
Channel |
Last |
Last byte to receive: Range 0-1 | |
Return |
PWMSetFrequency |
Sets PWM frequency in Hz | |
Channel |
Range: 0 - 11 | |
Frequency |
Frequency (Hz) | |
Return |
I2CStop |
Put the I2C Module into Stop mode | |
Channel |
Return |
ADCSetReferenceVoltage |
Specified the reference setting for ADC reads. | |
RefType |
0=AREF, 1=VCC, 3=Internal 1.1V | |
Return |
OneWireSkipROM |
Performs a bus reset and the sends the SkipROM command byte | |
Channel |
Return |
SPIPrescaler |
Modify the speed of the SPI bus | |
Channel |
Prescaler |
Range: 0-2 | |
Return |
PWMSetDuty |
Sets the duty for the PWM output | |
Channel |
Range: 0-11 | |
Duty |
Return |
ADCSample10 |
Reads the voltage present on an Analog pin as an 12-bit value range 0-4095 | |
ADCChannel |
Range: 0, 3-7 | |
Return |
IOSetOutputPin |
Sets the selected digital pin to an output and assigns the output state. | |
Pin |
Range: 0-29 | |
State |
Range: 0-1 | |
Return |
UARTReceive |
Receives a data byte from the UART. Recommend calling the UARTCheckRx function first to ensure data is available. | |
Channel |
Return |
OneWireScanBus |
Scans the one wire bus to detect all connected devices. Returns the number of one wire devices found. | |
Channel |
Return |
SPIInitialise |
Initialsie the SPI module ready for communications | |
Channel |
Return |
OneWireReceiveByte |
Receives a byte from the one wire bus a bit at a time | |
Channel |
Return |
I2CSend |
Transmit a byte using the I2C bus | |
Channel |
DataOut |
Return |
UARTSend |
Send a byte via the UART module | |
Channel |
Data |
Data Byte to send. Range: 0-255 | |
Return |
OneWireGetDeviceCount |
Returns the number of devices found by the last ScanBus operation. | |
Channel |
Return |
PWMEnable |
Enable a PWM output | |
Channel |
Range: 0-11 | |
Return |
Initialise |
Initialise the comms to the Arduino board ready for commands to be sent. | |
Return |
I2CInitialise |
Channel |
Baud |
Return |
IOGetInputPin |
Pin |
Range: 0-29 | |
Return |
OneWireInitialise |
Channel |
Return |
ADCSample8 |
ADCChannel |
Range: 0, 3-7 | |
Return |
UARTInitialise |
Channel |
Return |
UARTCheckRX |
Channel |
Return |
Channel |
Data |
Return |
I2CRestart |
Channel |
Return |
PWMDisable |
Channel |
Range: 0-11 | |
Return |
I2CStart |
Channel |
Return |
SPITransfer |
Channel |
DataOut |
Return |
I2CReceive |
Channel |
Last |
Return |
PWMSetFrequency |
Channel |
Range: 0 - 11 | |
Frequency |
Frequency (Hz) | |
Return |
I2CStop |
Channel |
Return |
RefType |
Return |
OneWireSkipROM |
Channel |
Return |
SPIPrescaler |
Channel |
Prescaler |
Range: 0-2 | |
Return |
PWMSetDuty |
Channel |
Range: 0-11 | |
Duty |
Return |
ADCSample10 |
ADCChannel |
Range: 0, 3-7 | |
Return |
IOSetOutputPin |
Pin |
Range: 0-29 | |
State |
Range: 0-1 | |
Return |
UARTReceive |
Channel |
Return |
OneWireScanBus |
Channel |
Return |
SPIInitialise |
Channel |
Return |
Channel |
Return |
I2CSend |
Channel |
DataOut |
Return |
UARTSend |
Channel |
Data |
Return |
Channel |
Return |
PWMEnable |
Channel |
Range: 0-11 | |
Return |
Initialise |
Return |
