Component: Quadrature Encoder (General Input)
Author | Matrix TSL |
Version | 1.5 |
Category | General Input |
Quadrature Encoder component
Quadrature Encoder component implements a rotary encoder connected to two pins. Quadrature Encoders provides incremental positioning rather than absolute positioning.
Please click here to view the component source code (Beta): FC_Comp_Source_Encoder_Quadrature.fcfx
Mechanical encoders can be a bit electrically noisy when switching and so to have reliable operation it is recommended to have a simple filter as shown here.
Polling
Example program showing how to use a quadrature encoder component using a polling method. Quad_Encoder_Test
Timer Interrupt Based Polling
Example program showing how to use a quadrature encoder component using a polling method via a timer interrupt. Quad_Encoder_Timer
Interrupt On Change
Example program showing how to use a quadrature encoder component using a interrupt on pin state change interrupt (IOC). Quad_Encoder_IOC
CheckForChanges | |
Polling function to check changes Returns 1 for chaged, 0 for no change, 255 for error | |
- BYTE | Return |
Disable | |
Disables the use of the quad encoder Once this ist called, the read functions will return zeros until the next Enable() call | |
- VOID | Return |
WriteCounter32 | |
Sets the value of the internal count variable. Range: -2147483648 to 2147483647 | |
- LONG | Value |
- VOID | Return |
Enable | |
Enables the use of the quad encoder If this is not called, the read functions will return zeros | |
- VOID | Return |
ReadCounter | |
Reads the current dial counter This is a counter from -32768 to 32767 | |
- INT | Return |
WriteCounter | |
Sets the value of the internal count variable. Range: -32768 to 32767 | |
- INT | Value |
- VOID | Return |
ResetCounter | |
Resets the current dial counter to zero | |
- VOID | Return |
ReadCounter32 | |
Reads the current dial counter as a 32-bit value This is a counter from -2147483648 to 2147483647 | |
- LONG | Return |
CheckForChanges | |
- BYTE | Return |
Disable | |
- VOID | Return |
WriteCounter32 | |
- LONG | Value |
- VOID | Return |
Enable | |
- VOID | Return |
ReadCounter | |
- INT | Return |
WriteCounter | |
- INT | Value |
- VOID | Return |
ResetCounter | |
- VOID | Return |
ReadCounter32 | |
- LONG | Return |
