Ribbon Toolbar
Revision as of 14:32, 15 May 2013 by ReeceL (talk | contribs)
The Flowcode environment consists of a main work area in which the flowchart windows are displayed, several toolbars that allow icon and components to be added to the flowchart application, windows that allow the status of the microcontroller and attached components to be viewed and windows that display variables and macro calls when the flow chart is being simulated.
<img>?
1) Icons Toolbar
2) Components Toolbar
This toolbar displays the external components that can be connected to a microcontroller. Click on a component and it will be added to the microcontroller in the Microcontroller view. The pin connections and properties of the component can then be edited.
Docking and Undocking the toolbars
<img>
<img>
3) Microcontroller View
4) Flowchart Window
5) Panel View
The status of one of the components attached to the microcontroller is displayed in this view. The component becomes 'active' when simulating the flowchart. The view also allows you to interact with external components for example, closing and opening switches.
6) Project Explorer
7) Icon Lists
8) Variables View
9) Call Stack View
This shows the current macro being simulated. This is useful when one macro calls another during the simulation process.
10) Toolbar
Use this command to display and hide the Toolbar, which includes buttons for some of the most common commands in Flowcode, such as File Open. There are also buttons for starting, stopping and pausing the simulation on the toolbar.
<img>
11) Status Bar
12) Current Zoom level
The currently selected Zoom level is displayed on the right side of the Status bar at the bottom of the program.
