Component: Formula AllCode API (AllCode)
Revision as of 15:14, 20 January 2023 by Wiki bot (talk | contribs)
Version 1.2
Category AllCode
Formula AllCode API component
A simulation only component to allow the Formula AllCode robot to be controlled via it's API interface and Bluetooth data connection without having to compile or re-program the robot.
Please click here to view the component source code (Beta): FC_Comp_Source_FormulaAllCode_API.fcsx
The COM port for the Formula AllCode can be set via the panel properties which can be exposed to the SCADA runtime user.
LED Control
Controls the LEDs on the Formula AllCode by collecting the analogue value of a potentiometer on the simulation panel and sending the value to the robot.
LED Control Example
Motor Control Using Keypad
Uses the keypad on the simulation panel to control the speed and direction of the motors. Key 2 drives the robot forwards, 8 drives backwards, 4 and 6 turn the robot on the spot.
Motor Control Example
Motor Control Using Joystick
A simple example showing how to drive the Formula AllCode robot around in API mode using a panel based joystick control.
Formula AllCode Bluetooth
Proximity Alarm
Reads the front IR sensor on the Formula AllCode from the Flowcode simulation. If a near object is sensed then the Flowcode simulation will speak the word "Hello" using the Speech component.
Proximity Alarm Example
Driving Simulation using the API component
An example showing how to use the API component to drive the Formula AllCode robot component on the simulation panel.
FA API Sim Demo
JCB Bot Blog
Blog with example code showing how to drive the Formula AllCode robot using Key Mappings and how to add extra features such as a 3D printed cover and servo motors to operate a digger arm and bucket.
JCB Bot
PlayNote
Plays a note using the speaker on the FA
- UINT Note
Range 1 to 65535 in Hz
- UINT Delay
Number of milliseconds to play the note for
LEDOn
Sets a single LED 0-7
- BYTE index
Range: 0-7
LCDPrintString
Prints a string to the LCD
- BYTE X
X Pixel 0-127
- BYTE Y
LCD Y Coordinate 0-31
- STRING Data
ReadLight
Reads the light sensor 0-4095 - 4095 = Max Brightness
Right
Rotates the robot right - waits for the angle to be traversed before returning
- UINT Angle
Angle to turn in degrees
SetLogoSpeed
Sets the speed of logo movements
- BYTE Speed
Logo Speed 1-100 - Default 40
ReadAllSensors
Samples all of the robot's sensors at once, storing the values locally
SampleMag
Samples the magnetometer 0 = no new data, 1 = new data available
CardCreate
Attempts to create a file on the SD card 255=Error, 1=File Already Exists, 0=Create OK
- STRING Filename
LCDPrintNumber
Prints a 16-bit signed number to the LCD
- BYTE X
X Pixel 0-127
- BYTE Y
LCD Y coordinate 0-31
- INT Number
Range -32768 to 32767
LEDOff
Clears a single LED 0-7
- BYTE index
Range: 0-7
LEDWrite
Sets the value of the LEDs as an 8-bit output
- BYTE Value
LED value 0=All Off, 255 = All On
ReadAxis
Reads a single X/Y/Z axis from the accelerometer sensor.
- BYTE index
0=X, 1=Y, 2=Z
- INT Return
ServoSetAutoMoveSpeed
Changes the speed of the auto movements Default - 1
- BYTE Speed
Range 1-50
CardPlayback
Plays back a .Wav file audio stream from the card
- STRING Filename
ReadMic
Reads the microphone sensor 0 - 4095
ReadSwitch
Read the switch value
- BYTE index
0 (left) or 1 (right)
SampleAccel
Samples the accelerometer 0 = no new data, 1 = new data available
Left
Rotates the robot left - waits for the angle to be traversed before returning
- UINT Angle
ReadIR
Reads an IR sensor 0=Left, 1=FrontLeft, 2=Front, 3=FrontRight, 4=Right, 5=RearRight, 6=Rear, 7=RearLeft
- BYTE index
LCDDrawPixel
Allows a single pixel on the LCD to be set or cleared
- BYTE X
X Pixel 0-127
- BYTE Y
Y Pixel 0-31
- BYTE State
0=White (Off), 1=Black (On)
ServoSetPosition
Allows one of the servo positions to be assigned
- BYTE Channel
Range 0-3
- BYTE Position
Range 0-255
CardBitmap
Displays a monochrome bitmap read from the card on the LCD
- BYTE X
Range 0-127
- BYTE Y
Range 0-31
- STRING Filename
CardRecordMic
Records an audio stream on the card from the microphone
- BYTE BitDepth
0=8-bit, 1=16-bit
- BYTE SampleRate
Sample Rate 0=8KHz, 1=16KHz
- UINT RecordTime
Time to record for in seconds, Range 0-65535
- STRING Filename
CardOpen
Attempts to open an existing file on the SD card 255=Error, 1=File not found, 0=Open OK
- STRING Filename
Forwards
Drives the robot forwards - waits for the distance to be traversed before returning
- UINT Distance
Distance in mm
ReadBearing
Reads the compass bearing based on the degrees clockwise from magnetic north.
- INT Return
GetConsoleHandle
- HANDLE Return
LCDDrawLine
Allows a single pixel width line to be drawn on the LCD
- BYTE X1
X Pixel 0-127
- BYTE Y1
Y Pixel 0-31
- BYTE X2
X Pixel 0-127
- BYTE Y2
Y Pixel 0-31
ServoAutoMoveToPosition
Allows one of the servo positions to move gradually to a new position
- BYTE Channel
Range 0-3
- BYTE Position
Range 0-255
ReadAllValue
Reads a single value stored from the read all command Index dictates which sensor value to read
- BYTE Index
0=SW, 1-8=IR, 9-10=Line, 11=Light, 12=Mic, 13-15=Accel
LCDBacklight
Allows the LCD backlight brighntess to be adjusted
- BYTE Intensity
Range 0-100, 0=Off, 1=Min Brightness, 100=Max Brightness
LCDDrawRect
Allows a rectangle to be drawn on the LCD
- BYTE X1
X Pixel 0-127
- BYTE Y1
Y Pixel 0-31
- BYTE X2
X Pixel 0-127
- BYTE Y2
Y Pixel 0-31
ReadLine
Reads one of the IR line sensors 0-1 0=Left, 1=Right
- BYTE index
0=Left, 1=Right
ServoDisable
Allows one of the servo outputs 0-3 to be disabled
- BYTE Channel
Range 0-3
ServoEnable
Allows one of the servo outputs 0-3 to be enabled
- BYTE Channel
Range 0-3
CardReadByte
Reads a byte from the currently open file. Starts at the beginning of the file and auto increments to the end
CardErase
Attempts to delete an existing file on the SD card 255=Error, 1=File not found, 0=Delete OK
- STRING Filename
CardWriteByte
Appends a byte to the end of the currently open file
- BYTE Data
EncoderRead
Reads one of the motor encoder counters. Approx 0.328296mm of travel per encoder unit.
- BYTE index
0=Left, 1=Right
SetMotors
Sets the motor speeds without feedback Range -100 to 100
- INT Left
Range -100 to 100
- INT Right
Range -100 to 100
Backwards
Drives the robot backwards - waits for the distance to be traversed before returning
- UINT Distance
Distance in mm
EncoderReset
Resets the motor encoder counters
LCDVerbose
Allows the LCD to automatically report the API commands as they get processed. Default - verbose on
- BYTE State
0=Off 1=On
SetProp
Allows the COM port property to be set from a parent component.
- STRING PropName
- ULONG PropVal
CardInit
Attempts to startup the SD card 255=No Card, 254=Init Fail, 0=Init OK
GetProp
Allows the property filter for the COM port list to be copied to a parent component.
- STRING PropName
- STRING Return
LCDClear
Clears the LCD
COM Port
Selects which port to communicate with, only lists ports which are currently available.
Refresh COM Ports
When set to yes the COM port list is rescanned for newly connected or available ports. Note that refreshing the ports list may take a few seconds depending on the number of connected ports.
Baud
Baud rate passed to the COM port to control the rate of data.
PlayNote
- UINT Note
- UINT Delay
LEDOn
- BYTE index
Range: 0-7
LCDPrintString
- BYTE X
X Pixel 0-127
- BYTE Y
- STRING Data
ReadLight
Right
- UINT Angle
SetLogoSpeed
- BYTE Speed
ReadAllSensors
SampleMag
CardCreate
- STRING Filename
LCDPrintNumber
- BYTE X
X Pixel 0-127
- BYTE Y
- INT Number
LEDOff
- BYTE index
Range: 0-7
LEDWrite
- BYTE Value
ReadAxis
- BYTE index
0=X, 1=Y, 2=Z
- INT Return
- BYTE Speed
Range 1-50
CardPlayback
- STRING Filename
ReadMic
ReadSwitch
- BYTE index
SampleAccel
Left
- UINT Angle
ReadIR
- BYTE index
LCDDrawPixel
- BYTE X
X Pixel 0-127
- BYTE Y
Y Pixel 0-31
- BYTE State
ServoSetPosition
- BYTE Channel
Range 0-3
- BYTE Position
Range 0-255
CardBitmap
- BYTE X
Range 0-127
- BYTE Y
Range 0-31
- STRING Filename
CardRecordMic
- BYTE BitDepth
0=8-bit, 1=16-bit
- BYTE SampleRate
- UINT RecordTime
- STRING Filename
CardOpen
- STRING Filename
Forwards
- UINT Distance
Distance in mm
ReadBearing
- INT Return
GetConsoleHandle
- HANDLE Return
LCDDrawLine
- BYTE X1
X Pixel 0-127
- BYTE Y1
Y Pixel 0-31
- BYTE X2
X Pixel 0-127
- BYTE Y2
Y Pixel 0-31
- BYTE Channel
Range 0-3
- BYTE Position
Range 0-255
ReadAllValue
- BYTE Index
LCDBacklight
- BYTE Intensity
LCDDrawRect
- BYTE X1
X Pixel 0-127
- BYTE Y1
Y Pixel 0-31
- BYTE X2
X Pixel 0-127
- BYTE Y2
Y Pixel 0-31
ReadLine
- BYTE index
0=Left, 1=Right
ServoDisable
- BYTE Channel
Range 0-3
ServoEnable
- BYTE Channel
Range 0-3
CardReadByte
CardErase
- STRING Filename
CardWriteByte
- BYTE Data
EncoderRead
- BYTE index
0=Left, 1=Right
SetMotors
- INT Left
Range -100 to 100
- INT Right
Range -100 to 100
Backwards
- UINT Distance
Distance in mm
EncoderReset
LCDVerbose
- BYTE State
0=Off 1=On
SetProp
- STRING PropName
- ULONG PropVal
CardInit
GetProp
- STRING PropName
- STRING Return
LCDClear
Clears the LCD
COM Port
Refresh COM Ports
Baud
