Component: GLCD (ST7567) SPI (Graphical Monochrome)
Revision as of 15:14, 20 January 2023 by Wiki bot (talk | contribs)
Version 1.5
Category Graphical Monochrome
GLCD (ST7567) SPI component
Graphical display component designed to work with the ST7567 type monochrome displays. Transfers data using a 4-wire SPI interface, cannot read back so pixel based routines won't work Not for public release.
Please click here to view the component source code (Beta): FC_Comp_Source_GLCD_ST7567_SPI.fcfx
ReadFontWidth
- BYTE Font
- BYTE Character
SetFontScaler
- BYTE ScaleX
- BYTE ScaleY
- INT Number
- UINT X
- UINT Y
- BYTE Font
- BYTE Transparent
DrawLine
- UINT X1
- UINT Y1
- UINT X2
- UINT Y2
Write_Data
- BYTE data
DrawEllipse
- UINT X
- UINT Y
- UINT XRadius
- UINT YRadius
- BYTE Transparent
- BYTE Solid
Goto_XY
- BYTE X
- BYTE Y
Plot
- UINT X1
- UINT Y1
SetDisplayOrientation
- BYTE Orientation
0=Default, 1=90??CW, 2=180??CW, 3=270??CW
BPlot
- UINT X1
- UINT Y1
ReadFontStat
- BYTE Font
- BYTE Index
0=SpaceWidth, 1=PixelHeight
Print
- STRING Str
- UINT X1
- UINT Y1
- BYTE Font
- BYTE Transparent
ClearDisplay
SetBackgroundColour
- BYTE PixelColour
0=White, 1=Black
DrawCircle
- UINT X
- UINT Y
- UINT Radius
- BYTE Transparent
- BYTE Solid
Write_Command
- BYTE Command
SetForegroundColour
- BYTE PixelColour
0=White, 1=Black
DrawRectangle
- UINT X1
- UINT Y1
- UINT X2
- UINT Y2
- BYTE Transparent
- BYTE Solid
Dimensions
Pixel Width
Pixel Height
Colour
Monochrome
Foreground Color
Background Color
Bit Depth
Color Bit Depth
Red Bit Depth
Green Bit Depth
Blue Bit Depth
Data Pin
Clock Pin
A0
CS
Chip select pin
Reset
Fonts
Font Count
Font 0
Font
Character Spacing
Space Width
Simulation Mode
Physical Orientation
LCDVersion
ReadFontWidth
- BYTE Font
- BYTE Character
SetFontScaler
- BYTE ScaleX
- BYTE ScaleY
- INT Number
- UINT X
- UINT Y
- BYTE Font
- BYTE Transparent
DrawLine
- UINT X1
- UINT Y1
- UINT X2
- UINT Y2
Write_Data
- BYTE data
DrawEllipse
- UINT X
- UINT Y
- UINT XRadius
- UINT YRadius
- BYTE Transparent
- BYTE Solid
Goto_XY
- BYTE X
- BYTE Y
Plot
- UINT X1
- UINT Y1
- BYTE Orientation
BPlot
- UINT X1
- UINT Y1
ReadFontStat
- BYTE Font
- BYTE Index
Print
- STRING Str
- UINT X1
- UINT Y1
- BYTE Font
- BYTE Transparent
ClearDisplay
SetBackgroundColour
- BYTE PixelColour
0=White, 1=Black
DrawCircle
- UINT X
- UINT Y
- UINT Radius
- BYTE Transparent
- BYTE Solid
Write_Command
- BYTE Command
SetForegroundColour
- BYTE PixelColour
0=White, 1=Black
DrawRectangle
- UINT X1
- UINT Y1
- UINT X2
- UINT Y2
- BYTE Transparent
- BYTE Solid
Dimensions
Pixel Width
Pixel Height
Colour
Monochrome
Foreground Color
Background Color
Bit Depth
Color Bit Depth
Red Bit Depth
Green Bit Depth
Blue Bit Depth
Data Pin
Clock Pin
A0
CS
Chip select pin
Reset
Fonts
Font Count
Font 0
Font
Character Spacing
Space Width
Simulation Mode
LCDVersion
