Component: GLCD (ST7789V) (Graphical Color)
Revision as of 15:14, 20 January 2023 by Wiki bot (talk | contribs)
Version 1.6
Category Graphical Color
GLCD (ST7789V) component
Graphical display component designed to work with the ST7789V 16-bit colour graphical controller IC.
Please click here to view the component source code (Beta): FC_Comp_Source_GLCD_ST7789V.fcfx
ReadFontWidth
- BYTE Font
- BYTE Character
BacklightOn
Switches on the backlight
SetFontScaler
- BYTE ScaleX
- BYTE ScaleY
- INT Number
- UINT X
- UINT Y
- BYTE Font
- BYTE Transparent
DrawLine
- UINT X1
- UINT Y1
- UINT X2
- UINT Y2
Plot
- UINT X1
- UINT Y1
DrawEllipse
- UINT X
- UINT Y
- UINT XRadius
- UINT YRadius
- BYTE Transparent
- BYTE Solid
FastPlot
SetDisplayOrientation
- BYTE Orientation
BacklightOff
Switches off the backlight
BPlot
- UINT X1
- UINT Y1
Window
Specifies a full screen or sub window of pixels to draw. Useful when used with the FastPlot function to draw bitmaps at high speed.
- UINT X1
- UINT Y1
- UINT X2
- UINT Y2
ReadFontStat
- BYTE Font
- BYTE Index
0=SpaceWidth, 1=PixelHeight
Print
- STRING Str
- UINT X1
- UINT Y1
- BYTE Font
- BYTE Transparent
ClearDisplay
SetBackgroundColour
- BYTE Red
- BYTE Green
- BYTE Blue
DrawCircle
- UINT X
- UINT Y
- UINT Radius
- BYTE Transparent
- BYTE Solid
SetForegroundColour
- BYTE Red
- BYTE Green
- BYTE Blue
DrawRectangle
- UINT X1
- UINT Y1
- UINT X2
- UINT Y2
- BYTE Transparent
- BYTE Solid
Dimensions
Pixel Width
Pixel Height
X Offset
Horizontal offset before the active display pixels.
Y Offset
Vertical offset before the active display pixels.
Colour
Monochrome
Foreground Color
Background Color
Invert Colours
Bit Depth
Colour Bit Depth
Red Bit Depth
Green Bit Depth
Blue Bit Depth
Data
Data pin connection
Clock
Clock pin connection
Use CS
Toggle CS
Selects if the chip select pin is automatically toggled or left selected. Yes - Slightly slower but allows pins to be multiplexed with other devices. No - Slightly faster.
Chip Select
Chip select pin connection
Use Reset
Reset
Reset Pin
Use Backlight
Backlight
Backlight Pin
Use DC Pin
Selects if the DC pins is available, Yes we use the DC pin to control if a data or commnd is being sent. No we add an extra bit to the data to do the job of the DC pin.
DC
Data/Command Pin
Fonts
Font Count
Font 0
Font
Character Spacing
Space Width
Component Label
Component Label Scale
Physical Orientation
ReadFontWidth
- BYTE Font
- BYTE Character
BacklightOn
SetFontScaler
- BYTE ScaleX
- BYTE ScaleY
- INT Number
- UINT X
- UINT Y
- BYTE Font
- BYTE Transparent
DrawLine
- UINT X1
- UINT Y1
- UINT X2
- UINT Y2
Plot
- UINT X1
- UINT Y1
DrawEllipse
- UINT X
- UINT Y
- UINT XRadius
- UINT YRadius
- BYTE Transparent
- BYTE Solid
FastPlot
- BYTE Orientation
BacklightOff
BPlot
- UINT X1
- UINT Y1
Window
- UINT X1
- UINT Y1
- UINT X2
- UINT Y2
ReadFontStat
- BYTE Font
- BYTE Index
Print
- STRING Str
- UINT X1
- UINT Y1
- BYTE Font
- BYTE Transparent
ClearDisplay
SetBackgroundColour
- BYTE Red
- BYTE Green
- BYTE Blue
DrawCircle
- UINT X
- UINT Y
- UINT Radius
- BYTE Transparent
- BYTE Solid
SetForegroundColour
- BYTE Red
- BYTE Green
- BYTE Blue
DrawRectangle
- UINT X1
- UINT Y1
- UINT X2
- UINT Y2
- BYTE Transparent
- BYTE Solid
Dimensions
Pixel Width
Pixel Height
X Offset
Y Offset
Colour
Monochrome
Foreground Color
Background Color
Invert Colours
Bit Depth
Colour Bit Depth
Red Bit Depth
Green Bit Depth
Blue Bit Depth
Data
Data pin connection
Clock
Use CS
Toggle CS
Chip Select
Use Reset
Reset
Reset Pin
Use Backlight
Backlight
Backlight Pin
Use DC Pin
DC
Data/Command Pin
Fonts
Font Count
Font 0
Font
Character Spacing
Space Width
Component Label
