| Author
Matrix Ltd.
| Version
2.1
| Category
Wireless
GPS (EB056, Generic NMEA) component
Component designed to process incoming NMEA style GPS data and convert into meaningful values such as longitude, lattitude, ground speed, UTC date and time. Also available in the form of the EB056 GPS E-block.
Please click here to view the component source code (Beta): FC_Comp_Source_GPS.fcfx
GPS Example File
GPS Example
Example should show the Latitude generated by the GPS injector as well as the system time in simulation or UTC time on hardware.
Example data provided by the GPS NMEA injector component
GPS tracking application using an Arduino and an SD card reader.
GPS Tracker
ReadGroundSpeed
| Returns the current ground speed. Only returns correct data if Log Ground Speed property is set to yes.
  - FLOAT
ReadNumberOfSatellites
| Returns the current detected number of satellites. Only returns correct data if Log Satellite Count property is set to yes.
  - BYTE
ReadDilutionOfPrecision
| Returns the current dilution of precision. Only returns correct data if Log Dilution Of Precision property is set to yes.
  - FLOAT
CheckBufferOverflow
| Returns the state of the buffer - 0 = OK, 1 = BufferTooShort, 2 = ItemNotFound. Only returns correct data if Log Buffer Overflow Property is set to Yes.
  - BYTE
ReadLongitude
| Returns the current longitude. Only returns correct data if Log Longitude property is set to yes.
  - FLOAT
ReadUTCTime
| Returns a segment of the current UTC Time. Only returns correct data if Log UTC Time property is set to yes.
  - BYTE
Unit
| Specifies which segment to read - 'h', 'm', 's'
  - BYTE
IsDataValid
| Returns the state of the incoming data - 0 = NotValid, 1 = Valid 255 = No GPS Data Received.
  - BYTE
ReadHorizontalDilutionOfPrecision
| Returns the current horizontal dilution of precision. Only returns correct data if Log HDOP property is set to yes.
  - FLOAT
ReadAltitude
| Returns the current altitude. Only returns correct data if Log Altitude property is set to yes.
  - FLOAT
ReadCourseOverGround
| Returns the current course over ground. Only returns correct data if Log Course Over Ground property is set to yes.
  - FLOAT
ReadUTCDate
| Returns a segment of the current UTC Date. Only returns correct data if Log UTC Date property is set to yes.
  - BYTE
Unit
| Specifies which segment to read - 'd', 'm', 'y'
  - BYTE
ReadVerticalDilutionOfPrecision
| Returns the current vertical dilution of precision. Only returns correct data if Log VDOP property is set to yes.
  - FLOAT
ReadLatitude
| Returns the current latitude. Only returns correct data if Log Latitude property is set to yes.
  - FLOAT
| Initialises the UART used to communicate with the GPS module.
Buffer Size
| The maximum number of bytes of a NMEA message we can store before processing the message.
Log Altitude
| Adds a variable to store the incoming altitude value Referenced by macro: ReadAltitude
Log Buffer Overflow
| Adds a variable to store if the incoming message buffer overflows Referenced by macro: CheckBufferOverflow
| Adds a variable to store the incoming course over ground value Referenced by macro: ReadCourseOverGround
| Adds a variable to store the incoming DOP value Referenced by macro: ReadDilutionOfPrecision
Log Ground Speed
| Adds a variable to store the incoming ground speed value Referenced by macro: ReadGroundSpeed
Log Horizontal DOP
| Adds a variable to store the incoming HDOP value Referenced by macro: ReadHorizontalDilutionOfPrecision
Log Latitude
| Adds a variable to store the incoming latitude value Referenced by macro: ReadLatitude
Log Longitude
| Adds a variable to store the incoming longitude value Referenced by macro: Read Longitude
Log Satellite Count
| Adds a variable to store the number of satellites in range Referenced by macro: ReadNumberOfSatellites
Log UTC Time
| Adds a variable to store the incoming UTC Time value Referenced by macro: ReadUTCTime
Log UTC Date
| Adds a variable to store the incoming UTC Date value Referenced by macro: ReadUTCDate
Log Verticle DOP
| Adds a variable to store the incoming VDOP value Referenced by macro: ReadVerticalDilutionOfPrecision
| UART Channel selector Software channels are bit banged using generic I/O pins but are not as reliable as hardware channels. Hardware channels use the selected peripheral on-board the target microcontroller.
RX
| Pin to be used for Receive data
Baud Options
| Baud rate option selector
| Label used to help identify the component on the panel.
Show Globe
| Allows a graphical globe to be shown on the panel along with a coordinate marker.
| Selects if the scope traces are automatically added to the data recorder window or not.     Simulation - draws an approximation of the UART data onto the scope trace.     ICT - sets up the scope trace for incoming data and adds UART packet decoding at the correct BAUD.
Console Columns
| Number of characters that can be displayed on a single line of the console.
Data Source
| Simulation data source used to allow the component to connect to various remote devices     Nothing - Simulation data is ignored     COM port - Routes the communication data to and from a physical or virtual COM port      Injector - Routes the communication data via a data injector component on the Panel.
ReadGroundSpeed
  - FLOAT
  - BYTE
  - FLOAT
CheckBufferOverflow
  - BYTE
ReadLongitude
  - FLOAT
ReadUTCTime
  - BYTE
Unit
  - BYTE
IsDataValid
  - BYTE
  - FLOAT
ReadAltitude
  - FLOAT
  - FLOAT
ReadUTCDate
  - BYTE
Unit
  - BYTE
  - FLOAT
ReadLatitude
  - FLOAT
Buffer Size
Log Altitude
Log Buffer Overflow
Log Ground Speed
Log Horizontal DOP
Log Latitude
Log Longitude
Log Satellite Count
Log UTC Time
Log UTC Date
Log Verticle DOP
RX
Baud Options
Show Globe
Console Columns
Data Source
