| Author
Matrix Ltd
| Version
1.0
| Category
Segment
4-Digit Display (Grove 104030003) component
Quad seven segment display using an two pin communications bus to reduce the number of control pins. Based on the Grove module 104030003.
Please click here to view the component source code (Beta): FC_Comp_Source_Grove_4_Digit_Display.fcfx
ShowDigits
| Set the number and decimal point to be displayed in the given digit of the display.
- BYTE
Value0
| The number value to set the digit to (0...15), 16=Clear
- BYTE
Value1
- BYTE
Value2
- BYTE
Value3
- BYTE
Colon
| Whether to show the colon character.
SetLEDs
| Allows the individual LEDs for one of the segments to be set. The colon character can also be controlled when writing to digit 1.
- BYTE
Digit
| Which of the four digits to change. (0...3)
- BYTE
Segments
| The binary segment control value. 0=Clear, 1=Set
ShowDigit
| Set the number to be displayed in the given digit of the display. The colon character can also be controlled when writing to digit 1.
- BYTE
Digit
- BYTE
Value
- BYTE
Colon
| Whether to show the colon character. Digit 1 only.
Display Type
| Set this according to the specification of your hardware display. Common Anode: Pin true -> LED Off, Pin false -> LED On Common Cathode: Pin true -> LED On, Pin false -> LED Off
Show Seg Labels
| Show segment name labels overlayed over the component.
DIO
| Data Pin connection to TM1637 IC
CLK
| Clock Pin connection to TM1637 IC
Colors
LED Color
| Color of the LED segments when truned on. When off, they use a much darker shade of the same hue.
Body Color
| Color of the plastic casing containing the LEDs.
Label Color
| Color for the optional LED segment labels.
ShowDigits
- BYTE
Value0
- BYTE
Value1
- BYTE
Value2
- BYTE
Value3
- BYTE
Colon
SetLEDs
- BYTE
Digit
- BYTE
Segments
ShowDigit
- BYTE
Digit
- BYTE
Value
- BYTE
Colon
Display Type
Show Seg Labels
DIO
CLK
Colors
LED Color
Body Color
Label Color
