Component: Keypad (4x4) (Keypad)
Revision as of 15:15, 20 January 2023 by Wiki bot (talk | contribs)
Category Keypad
Keypad component
Preset keypad based around the 4 * 4 unit.
Please click here to view the component source code (Beta): FC_Comp_Source_Keypad_4x4.fcfx
WaitPressed
Blocking call that waits for one of the keys on the keypad to be pressed. The index of the key that was pressed is passed back to the user.
GetAscii
Gets the ASCII value for the current keypress. If no key is pressed then the macro returns the value 255.
GetString
Gets the ASCII value for the current keypress and returns in the form of a string. If no key pressed then the macro returns the value 255.
- STRING Return
GetNumber
Gets the numeric value for the current keypress. If no key pressed then the macro returns the value 255.
GetIndex
Gets the index value for the current keypress. If no key pressed then the macro returns the value 255.
WaitReleased
Blocking call that waits for the keys on the keypad to be released. If no key is pressed then the function will return immediatley.
Output Mode
Port
Backplate Colour
Button 1
Key colour
Set the colour of the key body here. This is applied to all objects making up a key, including the background colour of any text labels.
Label colour
Set the colour for the default 'ASCII' text label on the key-cap. This setting will be ignored if a bitmap is set for the key label.
Button 2
Key colour
Label colour
Button 3
Key colour
Label colour
Button 4
Key colour
Label colour
Button 5
Key colour
Label colour
Button 6
Key colour
Label colour
Button 7
Key colour
Label colour
Button 8
Key colour
Label colour
Button 9
Key colour
Label colour
Button 10
Key colour
Label colour
Button 11
Key colour
Label colour
Button 12
Key colour
Label colour
Button 13
Key colour
Label colour
Button 14
Key colour
Label colour
Button 15
Key colour
Label colour
Button 16
Key colour
Label colour
WaitPressed
GetAscii
GetString
- STRING Return
GetNumber
GetIndex
WaitReleased
Output Mode
Port
Backplate Colour
Button 1
Key colour
Label colour
Button 2
Key colour
Label colour
Button 3
Key colour
Label colour
Button 4
Key colour
Label colour
Button 5
Key colour
Label colour
Button 6
Key colour
Label colour
Button 7
Key colour
Label colour
Button 8
Key colour
Label colour
Button 9
Key colour
Label colour
Button 10
Key colour
Label colour
Button 11
Key colour
Label colour
Button 12
Key colour
Label colour
Button 13
Key colour
Label colour
Button 14
Key colour
Label colour
Button 15
Key colour
Label colour
Button 16
Key colour
Label colour
