Component: LED Matrix Dummy (HT16K33) (Outputs: LEDs)
Revision as of 15:15, 20 January 2023 by Wiki bot (talk | contribs)
Version 1.2
Category Outputs: LEDs
LED Matrix Dummy component
LED Matrix component designed to work using a HT16K33 LED driver IC. Can drive up to 16 x 8 (128) LEDs. Includes support for 8x16 Backpack, 16x8 Featherwing, 8x8 Backpack and Custom.
Please click here to view the component source code (Beta): FC_Comp_Source_LED_Matrix_HT16K33_Dummy.fcfx
LED Resistor Calculator Tool
DisplayString
Prints an ASCII string onto the LED Matrix a column at a time.
- STRING Data
Data string to display on the LEDs
- UINT Animation_Delay
Delay in milliseconds between writing to the next column
- BYTE Leadout
Allows the text to scroll completely off the display before returning 0=No, 1=Yes
- BYTE Add_Spaces
Add spaces between each ASCII character 0=No, 1=Yes
- BYTE Orientation
0=Normal, 1=Rotated 90 Degrees
SetBrightness
Configures the brightness of the LEDs by varying the On portion of the duty.
- BYTE Brightness
Range: 0-15 - 0 = Min Brightness, 15 = Full Brightness
ShiftColumns
Shifts the columns one place left or right. Used for things like displaying scrolling text.
- BYTE Direction
0 = Shift Left, 1 = Shift Right
ClearLEDs
Sets all of the LEDs in the matrix to the off state.
WriteLED
Allows a single LED to be controlled using the basic column / row coordinate system. Each column is comprised of 8 rows.
- BYTE Column
Range: 0-15
- BYTE Row
Range: 0-7
- BYTE Data
0 = LED Off, 1 = LED On
WriteLEDXY
Allows a single LED to be controlled using a more standard X, Y coordinate system. 0,0 refers to the bottom left hand LED. Only works with the fixed display modules, custom module not supported.
- BYTE X
X coordinate. Range: 0-15
- BYTE Y
Y coordinate. Range: 0-15
- BYTE State
State 0=Off, 1=On
WriteCommand
Writes a command.
- BYTE Command
WriteColumn
Allows a single column of 8 LEDs to be controlled in a single action.
- BYTE Column
Range: 0-15
- BYTE Data
Data to display on the column of LEDs
WriteRegister
Writes a value to a register.
- BYTE Address
- BYTE Value
Configures the I2C peripheral and sets up the HT16K33 IC ready to drive the LEDs.
Display Module
LED Count
Total number of LEDs in the component
Slave Address
Channel selection
Baud Select
Baud rate to be used
Stop Delay
SDA
SCL
Colours
On Color
Simulated colour of the LEDs when switched On
Off Color
Simulated colour of the LEDs when switched Off
Simulation Type
Sets the simulation type. Component GUI allows the object on the panel to reflect what the reakl life LED matrix should do. I2C Injector allows the I2C communications to be simulated via injectors.
GUI
Column Spacing
Simulation column spacing
Width
Simulation LED width
Row Spacing
Simulation row spacing
Height
Simulated LED height
Depth
Simulated LED Depth (3D environments only)
LED Shape
Simulated LED basic shape
DisplayString
- STRING Data
- BYTE Leadout
- BYTE Add_Spaces
- BYTE Orientation
SetBrightness
- BYTE Brightness
ShiftColumns
- BYTE Direction
ClearLEDs
WriteLED
- BYTE Column
Range: 0-15
- BYTE Row
Range: 0-7
- BYTE Data
WriteLEDXY
- BYTE X
- BYTE Y
- BYTE State
State 0=Off, 1=On
WriteCommand
Writes a command.
- BYTE Command
WriteColumn
- BYTE Column
Range: 0-15
- BYTE Data
WriteRegister
- BYTE Address
- BYTE Value
Display Module
LED Count
Slave Address
Channel selection
Baud Select
Stop Delay
SDA
SCL
Colours
On Color
Off Color
Simulation Type
GUI
Column Spacing
Width
Row Spacing
Height
Depth
LED Shape
