Component: LED Mono (LED)
| Category | LED |
LED Mono component
Please click here to view the component source code (Beta): FC_Comp_Source_LED_Mono_2dgi.fcfx
Here is an example Flowcode program to read the value of a switch and change the state of LED accordingly.
LED Example
| TurnOn | |
| SetState | |
| Sets the state of the LED, accounting for the polarity. | |
| State | |
| 1=On, 0=Off | |
| TurnOff | |
| TurnOn | |
| SetState | |
| State | |
| 1=On, 0=Off | |
| TurnOff | |
