| Author
Matrix TSL
| Version
1.5
| Category
LEDs
RGB LED WS2811 / WS2812 / APA106 component
A simple chained RGB LED controller IC allowing multiple LEDs to be controlled using a serial data stream. Compatible with the WS2811, WS2812, WS2812B, APA104 and APA106 Type Controller ICs. Allows RGB LEDs to be driven with full 24-bit colour depth. Allows single chains, 2D arrays and 3D cube formations to be simulated. Requires a high speed microcontroller to generate the critical timings to drive the device.
Please click here to view the component source code (Beta): FC_Comp_Source_LED_WS2811.fcfx
SetBrightness
| Allows the output colour brightness of the LEDs to be scaled down. For example to save current usage or to reduce brightness in dark environments.
- FLOAT
Scaler
| Range: 0.0 to 1.0 Default: 1.0, 0 = Off, 0.5 = Half Brightness, 1.0 = Full Brightness
GetLEDColour
| Sets the colour of a single LED in RAM as a 1D array.
- UINT
LED
| LED to change the colour / Range: 0 to (LED Count - 1)
- BYTE
ColIdx
| 0 = Red, 1 = Green, 2 = Blue
- BYTE
OutputLow
SetBrightnessByte
- BYTE
Scaler
| Range: 0 to 255 Default: 255, 0 = Off, 128 = Half Brightness, 255 = Full Brightness
Delay_T0L
DrawLine2D
| Draws a line on a 2D array of LEDs
- UINT
X1
| Start X Coordinate
- UINT
Y1
| Start Y Coordinate
- UINT
X2
| End X Coordinate
- UINT
Y2
| End Y Coordinate
- BYTE
R
| Red colour channel
- BYTE
G
| Green colour channel
- BYTE
B
| Blue colour channel
OutputHigh
SetLEDColour
- UINT
LED
- BYTE
R
| Red Colour Channel
- BYTE
G
| Green Colour Channel
- BYTE
B
| Blue Colour Channel
SetAllLEDColour
| Sets the colour of all the LEDs in RAM
- BYTE
R
| Red Colour Channel
- BYTE
G
- BYTE
B
| Blue Colour Channel
Delay_T0H
Delay_T1L
Refresh
| Clocks out the current colour data to the LEDs from the values stored in RAM
ShiftLEDs1D
| Shifts the LED colours in 1D and wraps
- BYTE
Direction
| 0 = Forwards, 1 = Backwards
- BYTE
DataMode
| 0=ResetToZero, 1=WrapAroundDisplay, 2=Smear
DrawLine3D
| Draws a line on a 3D array of LEDs
- UINT
X1
| Start X Coordinate
- UINT
Y1
| Start Y Coordinate
- UINT
Z1
| Start Z Coordinate
- UINT
X2
| End X Coordinate
- UINT
Y2
| End Y Coordinate
- UINT
Z2
| End Z Coordinate
- BYTE
R
| Red Colour Channel
- BYTE
G
- BYTE
B
| Blue Colour Channel
Delay_T1H
GetLEDIndex2D
| Sets the index of a single LED in RAM as a 2D array.
- UINT
X
| LED Column to change the colour / Range: 0 to (LED Column - 1)
- UINT
Y
| LED Row to change the colour / Range: 0 to (LED Row - 1)
- UINT
DrawRectangle2D
| Draws a basic 2D rectangle onto the LEDs
- BYTE
X1
- BYTE
Y1
- BYTE
X2
- BYTE
Y2
- BYTE
DrawStyle
| Sets the draw style - 0=Soild, 1=Edge, 2=Corners
- BYTE
R
- BYTE
G
- BYTE
B
ShiftLEDs2D
| Shifts the contents of the display by the number of vertices specified ***Please Note that Wrap mode is currently unavailable***
- INT
X
| Number of pixels to shift the display -1 to 1 / 0 = No Shift
- INT
Y
- BYTE
DataMode
GetLEDIndex3D
| Gets the index of a single LED in RAM as a 3D array.
- UINT
X
- UINT
Y
- UINT
Z
| LED Layer to change the colour / Range: 0 to (LED Layer - 1)
- UINT
DrawCuboid3D
| Draws a basic 3D cuboid onto the LEDs
- BYTE
X1
| Start X pixel coordinate
- BYTE
Y1
| Start Y pixel coordinate
- BYTE
Z1
| Start Z pixel coordinate
- BYTE
X2
| End X pixel coordinate
- BYTE
Y2
| End Y pixel coordinate
- BYTE
Z2
| End Z pixel coordinate
- BYTE
DrawStyle
- BYTE
R
| Red Colour Channel
- BYTE
G
- BYTE
B
| White Colour Channel
| Inisialises the RGB colour RAM to 0,0,0 = LED Off and clocks out the data to initialise all the LED ICs in the chain.
ShiftLEDs3D
- INT
X
- INT
Y
- INT
Z
- BYTE
DataMode
Controller IC
LED Controller
| Allows the user to select which LED controller IC they are using. The different controller ICs all work the same way but have different timing characteristics.
Data Order
| Configures the order the colour data is clocked out to the LEDs
Reset Time (uS)
| Blanking reset period to reset the LED shift chain and start from the beginning
T0H (uS)
| Logic 0 high time in microseconds
T0L (uS)
| Logic 0 low time in microseconds
T1H (uS)
| Logic 1 high time in microseconds
T1L (uS)
| Logic 1 low time in microseconds
LED Properties
LED Arrangement
| Controls the arrangement of the LEDs on the panel. 1D - Creates a straight line of LEDs 2D - Creates an X by Y Array of LEDs 3D - Creates an X by Y by Z Array of LEDs
LED Count
| Total number of LEDs in the design
Arrangement
| LEDs will likely be arranged in one of two ways. Parallel = Each row of LEDs run from left to right - easier to address but harder to wire. Alternating = Each row of LEDs runs in an alternating direction - harder to address but easier to wire.
Column Count
| Number of horizontal LEDs - X axis
Column Spacing
| X Spacing Between LEDs on the Panel
Row Count
| Number of vertical LEDs - Y axis
Row Spacing
| Y Spacing Between LEDs on the Panel
Layer Count
| Number of LED layers - Z axis
Layer Spacing
| Z Spacing Between LEDs on the Panel
Flip X
| Flips the X axis if the LEDs are wired from the right hand side of the display.
Flip Y
| Flips the Y axis if the LEDs are wired from the under side of the display.
Flip Z
| Flips the X axis if the LEDs are wired from the upper most side of the display.
Data Pin
| LED Data Pin - Connected to the Data In pin of the first WS821x IC.
Invert Data
SetBrightness
- FLOAT
Scaler
GetLEDColour
- UINT
LED
- BYTE
ColIdx
- BYTE
OutputLow
SetBrightnessByte
- BYTE
Scaler
Delay_T0L
DrawLine2D
- UINT
X1
| Start X Coordinate
- UINT
Y1
| Start Y Coordinate
- UINT
X2
| End X Coordinate
- UINT
Y2
| End Y Coordinate
- BYTE
R
| Red colour channel
- BYTE
G
- BYTE
B
| Blue colour channel
OutputHigh
SetLEDColour
- UINT
LED
- BYTE
R
| Red Colour Channel
- BYTE
G
- BYTE
B
| Blue Colour Channel
SetAllLEDColour
- BYTE
R
| Red Colour Channel
- BYTE
G
- BYTE
B
| Blue Colour Channel
Delay_T0H
Delay_T1L
Refresh
ShiftLEDs1D
- BYTE
Direction
- BYTE
DataMode
DrawLine3D
- UINT
X1
| Start X Coordinate
- UINT
Y1
| Start Y Coordinate
- UINT
Z1
| Start Z Coordinate
- UINT
X2
| End X Coordinate
- UINT
Y2
| End Y Coordinate
- UINT
Z2
| End Z Coordinate
- BYTE
R
| Red Colour Channel
- BYTE
G
- BYTE
B
| Blue Colour Channel
Delay_T1H
GetLEDIndex2D
- UINT
X
- UINT
Y
- UINT
DrawRectangle2D
- BYTE
X1
- BYTE
Y1
- BYTE
X2
- BYTE
Y2
- BYTE
DrawStyle
- BYTE
R
- BYTE
G
- BYTE
B
ShiftLEDs2D
- INT
X
- INT
Y
- BYTE
DataMode
GetLEDIndex3D
- UINT
X
- UINT
Y
- UINT
Z
- UINT
DrawCuboid3D
- BYTE
X1
- BYTE
Y1
- BYTE
Z1
- BYTE
X2
- BYTE
Y2
- BYTE
Z2
- BYTE
DrawStyle
- BYTE
R
| Red Colour Channel
- BYTE
G
- BYTE
B
ShiftLEDs3D
- INT
X
- INT
Y
- INT
Z
- BYTE
DataMode
Controller IC
LED Controller
Data Order
Reset Time (uS)
T0H (uS)
T0L (uS)
T1H (uS)
T1L (uS)
LED Properties
LED Arrangement
LED Count
Arrangement
Column Count
Column Spacing
Row Count
Row Spacing
Layer Count
Layer Spacing
Flip X
Flip Y
Flip Z
Data Pin
Invert Data
