Component: Piezo Sounder (Audio Output)
| Category | Audio Output |
Piezo Sounder component
Drives a simple variable frequency piezo sounder in hardware and simulates the sound in simulation. To actually drive a piezo you may have to amplify the signal from the microcontroller using a transistor or MOSFET.
Please click here to view the component source code (Beta): FC_Comp_Source_PiezoSounder.fcfx
Here is a simple example that will create a siren effect using a piezo sounder.
Piezo Siren
Depending on your Piezo Sounder you may need to amplify the signal from the microcontroller using a NPN transistor or N channel FET.
| BuzzerOnDelay | |
| Switch the Buzzer on for a fixed amount of time | |
| Time | |
| Time in milliseconds to keep the buzzer on | |
| Frequency | |
| Frequency to output in Hz | |
| Properties | |
| Output Pin | |
| Pin used to drive the output to the buzzer | |
| BuzzerOnDelay | |
| Time | |
| Frequency | |
| Properties | |
| Output Pin | |
