Component: Serial EEPROM (24C01 - 24C16) (EEPROM)
Revision as of 15:16, 20 January 2023 by Wiki bot (talk | contribs)
Version 2.0
Category EEPROM
Serial EEPROM (24C01 - 24C16) component
Serial (I2C) EEPROM component for 24C01 to 24C16
Please click here to view the component source code (Beta): FC_Comp_Source_Serial_EEPROM_(24C16).fcfx
Read
Read and return the value of the EEPROM at the given address
- UINT address
ReadPage
- UINT address
- BYTE data
- BYTE count
Write
Write the given data value to the EEPROM at the given address
- UINT address
- BYTE data
WritePage
- UINT address
- BYTE data
- BYTE count
Range: 1-128
Device Address
Device address bits, these must match the address pins on the EEPROM IC.
Channel selection
SDA
SCL
Baud Select
Baud rate to be used
Stop Delay
Simulate Comms
No - Provides simulation using a local memory buffer Yes - Provides I2C simulation which can be passed via an API device to real world hardware
Read
- UINT address
ReadPage
- UINT address
- BYTE data
- BYTE count
Write
- UINT address
- BYTE data
WritePage
- UINT address
- BYTE data
- BYTE count
Range: 1-128
Device Address
Channel selection
SDA
SCL
Baud Select
Stop Delay
Simulate Comms
