Component: Serial EEPROM (24C32) (EEPROM)
Revision as of 15:16, 20 January 2023 by Wiki bot (talk | contribs)
Version 2.2
Category EEPROM
Serial EEPROM (24C32) component
Serial (I2C) EEPROM component for 24C32 Can be added to a MIAC project to give read and write access to the internal non-volatile memory device (if fitted, depending upon model).
Please click here to view the component source code (Beta): FC_Comp_Source_Serial_EEPROM_(24C32).fcfx
Read
Read and return the value of the EEPROM at the given address
- UINT address
Write
Write the given data value to the EEPROM at the given address
- UINT address
- BYTE data
Device Address
Device address bits, these must match the address pins on the EEPROM IC.
Channel selection
Baud Select
Baud rate to be used
Stop Delay
SDA
SCL
Simulate Comms
Read
- UINT address
Write
- UINT address
- BYTE data
Device Address
Channel selection
Baud Select
Stop Delay
SDA
SCL
Simulate Comms
