Component: Stepper Motor (Mechatronics)
Revision as of 15:17, 20 January 2023 by Wiki bot (talk | contribs)
Version 1.2
Category Mechatronics
Stepper Motor component
A component to drive stepper motor either using direct transistors or using an external stepper driver IC. Complete with 2D based panel simulation of the motor including coils and waveforms.
Please click here to view the component source code (Beta): FC_Comp_Source_StepperMotor_2d.fcfx
IncrementStep
Move the motor forward by one step.
DecrementStep
Move the motor backwards by one step.
EnableMotor
Turn on the motor. This must be done before it will respond to any other macros.
DisableMotor
Turn off the motor. It will no longer respond to any other macros.
GetSimAngle
Gets the angle of the simulated motor shaft in degrees.
- FLOAT Return
Driver
Coil 1
Chip pin to which the first motor coil is connected.
Coil 2
Chip pin to which the second motor coil is connected.
Coil 3
Chip pin to which the third motor coil is connected.
Coil 4
Chip pin to which the fourth motor coil is connected.
Motor Setup
Step Type
Trade accuracy against torque by changing the type of stepping. Refer to the data-sheet for your chosen hardware to determine which modes your device supports.
Show Pin Labels
Label Colour
Waveforms
Allows waveforms to be auto generated on the data recorder window.
Motor Simulation
Steps Per Revolution
The number of steps it takes for the motor shaft to turn a full circle (360 degrees). Refer to the data-sheet for your chosen hardware to determine this value.
Angle Increment
Amount of change in the shaft angle when the IncrementStep / DecrementStep functions are called.
Coil Simulation
Coil Simulation
Turn coil simulation on and off.
Colour Non Active Coil
Make coil object this colour when they are NOT energised.
Colour Active Coil
Make the coil objects this colour when they ARE energised,.
IncrementStep
DecrementStep
EnableMotor
DisableMotor
GetSimAngle
- FLOAT Return
Driver
Coil 1
Coil 2
Coil 3
Coil 4
Motor Setup
Step Type
Show Pin Labels
Label Colour
Waveforms
Motor Simulation
Angle Increment
Coil Simulation
Coil Simulation
Colour Active Coil
