Component: Wii Nunchuk (Movement Orientation)
Revision as of 15:17, 20 January 2023 by Wiki bot (talk | contribs)
Version 2.0
Category Movement Orientation
Wii Nunchuk component
A component to interface the Wii Nunchuck which features a 3-axis 10-bit Accelerometer A 2-axis 8-bit joystick and two digital button inputs. Interfaced using a standard I2C bus at 100KHz. Nunchuk must be powered at 3V3 to avoid damage.
Please click here to view the component source code (Beta): FC_Comp_Source_WiiNunchuck.fcfx
SimReset1G
Resets the simulation to 0.0 on X and Y and 1.0 on Z as if the accelerometer was sitting completely horizontal.
ReadJoystick
Reads a single joystick axis
- BYTE Axis
0=X, 1=Y
- INT Return
ReadSwitch
Reads one of the nunchuck switches
- BYTE Switch
0=Z, 1=C
- BOOL Return
Sample
Reads from the nunchuck and updates the local variables.
ReadAccelerometer
Reads a single Accelerometer axis
- BYTE Axis
0=X, 1=Y, 2=Z
- INT Return
Sets up up the communication bus and initialises the accelerometer module. Returns 1 for success and 0 for fail.
Bit Depth
The number of binary bits used to store the sensor's X,Y,Z readings.
Encryption
Decides if encryption should be active or disabled
Channel selection
Baud Select
Baud rate to be used
SDA
SCL
Stop Delay
Simulate Comms
Yes: Accelerometer data will come from the simulation component sliders. No: Accelerometer data will come from the CAL component - I2C or SPI - API etc
SimReset1G
ReadJoystick
- BYTE Axis
0=X, 1=Y
- INT Return
ReadSwitch
- BYTE Switch
0=Z, 1=C
- BOOL Return
Sample
ReadAccelerometer
- BYTE Axis
0=X, 1=Y, 2=Z
- INT Return
Bit Depth
Encryption
Channel selection
Baud Select
SDA
SCL
Stop Delay
Simulate Comms
