Component: Sim Switch (Push, PCB, SMT) (Misc)
| Author | Matrix Ltd |
| Version | 1.2 |
| Category | Misc |
Sim Switch (Push, PCB, SMT) component
Surface mount sim only click switch, standard 6mm square size.
Please click here to view the component source code (Beta): FC_Comp_Source_sw_push_pcb_smd_Sim.fcfx
Switch
(5V / 11K) * 10K = 4.54545V
| GetState | |
| Properties |
| GetState | |
| Properties |
