Component: Switch Array (Slide) (Switches)
Revision as of 15:18, 20 January 2023 by Wiki bot (talk | contribs)
Author Matrix Ltd.
Version 2.0
Category Switches
Switch Array (Slide) component
An array of up to eight slide switches, each connected to a single pin of the specified port.
Please click here to view the component source code (Beta): FC_Comp_Source_switch_array_slide.fcfx
Here is an example Flowcode program to read the values of a switch array. Switch Array
(5V / 11K) * 10K = 4.54545V
ReadState
Read the state of the switch at the given index.
- BYTE Index
The switch to read the status of.
- BOOL Return
WaitUntilHigh
Pause the program until the switch at the given index is turned on.
- BYTE Index
Index of the switch to wait for.
ReadAll
Reads all of the switches at once, returning a byte containing one bit per switch.
GetHandle
Retrieves the object handle of the switch component at the given index.
- BYTE Index
- HANDLE Return
WaitUntilLow
- BYTE Index
Count
The number of LEDs in the array from 1 to 8.
Input Mode
Choose a single port for all LEDs - pins are allocated in sequence from pin 0 - 7 ...or choose 'Custom pins' to assign each switch individually.
Port
Polarity
Active High = LEDs light when the chosen chip pin is ON Active Low = LEDs light when the chosen chip pin is OFF
Debounce
Time in milliseconds allowed for the pin to settle following a change of state.
Operation
Sets whether switches toggle or are press/release. NB) This option can only be set when the original target includes this option.
Alignment
Which 3D axis to align the copies along.
Spacing
The distance between LEDs in the array. LEDs will be spaced symmetrically around the component centre. Use a negative value to reverse the order of the LEDs.
Reverse
Whether to reverse the order of the switches.
Show Labels
Whether to show labels giving each switch's pin connection.
Label color
Color of the port and pin labels
ReadState
- BYTE Index
- BOOL Return
WaitUntilHigh
- BYTE Index
ReadAll
GetHandle
- BYTE Index
- HANDLE Return
WaitUntilLow
- BYTE Index
Count
Input Mode
Port
Polarity
Debounce
Operation
Alignment
Spacing
Reverse
Show Labels
Label color
