| Author
Matrix Ltd
| Version
1.1
| Category
Light
Beam Breaker component
Automatically sets and resets a pin depending on whether a panel object breaks the 'light beam'. Can also send simulation notification events.
Please click here to download the component source project: FC_Comp_Source_Beam_breaker.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_Beam_breaker.fcfx
ReadState
| Get the current collision state. The 'Polarity' property will affect whether a collision is represented by a high or low state.
- BYTE
SetTarget
| Set the object that you want to test for collision with. If this is not called, or is called with handle = 0, collisions will be tested against every panel object that has 'Solid' status. NB) Specifying an object will save CPU power!!
- HANDLE
Target
| The object to test for collision with.
WaitUntilHigh
| Pause the program until the detector goes high. 'Polarity' will affect whether high value represents a collision or separation. NB) In simulation, only use this macro if testing for collision with animated or timer driven objects!!
WaitUntilLow
| Pause the program until the detector goes low. 'Polarity' will affect whether low value represents a collision or separation. NB) In simulation, only use this macro if testing for collision with animated or timer driven objects!!
Pin
| Chip pin that the beam breaker is connected to,.
Polarity
| Active High = Pin is on when beam is broken, off when beam is intact. Active Low = Pin is off when beam is broken, on when beam is intact.
Target
| Choose a specific object to test for breaking the beam. If none is chosen, will check against any other object with 'Solid' status - note, checking all objects increases the CPU load!!
Range
| Set the distance between the transmitter and receiver
Show Beam
| Shows the 'light beam' on screen - arrow points from transmitter to receiver.
Timer Interval (ms)
| Time in milliseconds between collision scans. Small time = Greater CPU load Large time = More like to miss brief collisions.
Notification
Notify
| Whether or not to notify the component parent of any changes. Data will be zero or one (the current pin value).
ReadState
- BYTE
SetTarget
- HANDLE
Target
WaitUntilHigh
WaitUntilLow
Pin
Polarity
Target
Range
Show Beam
Timer Interval (ms)
Notification
Notify
ReadState
- BYTE
SetTarget
- HANDLE
Target
WaitUntilHigh
WaitUntilLow
Pin
Polarity
Target
Range
Show Beam
Timer Interval (ms)
Notification
Notify
