Author
Matrix Ltd
Version
1.5
Category
Buffer
Circular Buffer Free Sim component
Circular buffer component allowing easy and efficient first in first out (FIFO) style data byte storage. Useful when used with a comms component to capture data as it comes in ready for processing when we have time. Also features macros to allow you to check for specific incoming responses such as "OK" or "ERROR".
Please click here to download the component source project: FC_Comp_Source_CircularBuffer_FreeSim.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_CircularBuffer_FreeSim.fcfx
LookForValue
Scans the buffer for an array of specific values. Returns 0 if the value is not found. Returns 1 if the value is found.
- STRING
Value
Value to look for
- BYTE
NumChars
- BYTE
RemoveContent
0=Leave data alone, 1=Remove data from buffer
- BYTE
ResetFind
0=Continue the find from the last operation, 1=Start again
- BYTE
GetIndexedByte
Gets the value of a single byte at a known location in the buffer. Leaves the buffer contents and pointers untouched.
- UINT
address
- BYTE
WaitForValue
Waits for an array of values to appear in the circular buffer. Returns 0 to indicate a timeout. Returns 1 to indicate the data has been found.
- STRING
Value
- BYTE
NumChars
Number of characters to try and look for
- BYTE
RemoveContent
0=Leave the buffer contents untouched, 1=Remove values as you go
- UINT
Timeout
Max amount of time to wait in milliseconds before returning 0=WaitForever
- BYTE
GetNumberBytes
Returns the number of valid data bytes currently inside the buffer.
- UINT
GetConsoleHandle
- HANDLE
PeekByte
Reads the next available byte from the circular buffer without advancing the current index, Returns 255/512 if the buffer is empty.
- UINT
PutByte
Add byte to the next free location inside the circular buffer. If the data goes into the buffer correctly then return 1. Otherwise the buffer is full and the return value will equal 0.
- BYTE
Data
- BYTE
GetByte
Reads the next available byte from the circular buffer, Returns 255/512 if the buffer is empty.
- UINT
FlushBuffer
Clears the contents of the buffer and re-initialises the index locations.
Buffer Size
Sets the number of byte elements inside the circular buffer.
Storage Type
When buffer is full this property decides what to do. Store first x values - Will retain the information inside the buffer, new data will be discarded. Store last x values - Will discard the oldest location in the buffer and overwrite with new data.
Memory Type
Return Type
Specifies the way the receive function indicates a timeout. 8 Bit mode - Timeout is represented by the value 255. 16 Bit mode - Timeout is represented by the value 512 allowing the value 255 to represent valid data
Console
Decides if the contents of the buffer are shown in a console tab.
LookForValue
- STRING
Value
Value to look for
- BYTE
NumChars
- BYTE
RemoveContent
- BYTE
ResetFind
- BYTE
GetIndexedByte
- UINT
address
- BYTE
WaitForValue
- STRING
Value
- BYTE
NumChars
- BYTE
RemoveContent
- UINT
Timeout
- BYTE
GetNumberBytes
- UINT
GetConsoleHandle
- HANDLE
PeekByte
- UINT
PutByte
- BYTE
Data
- BYTE
GetByte
- UINT
FlushBuffer
Buffer Size
Storage Type
Memory Type
Return Type
Console
LookForValue
- STRING
Value
Value to look for
- BYTE
NumChars
- BYTE
RemoveContent
- BYTE
ResetFind
- BYTE
GetIndexedByte
- UINT
address
- BYTE
WaitForValue
- STRING
Value
- BYTE
NumChars
- BYTE
RemoveContent
- UINT
Timeout
- BYTE
GetNumberBytes
- UINT
GetConsoleHandle
- HANDLE
PeekByte
- UINT
PutByte
- BYTE
Data
- BYTE
GetByte
- UINT
FlushBuffer
Buffer Size
Storage Type
Memory Type
Return Type
Console
