Component: Temp / Humidity (DHT22) (Environmental)
Revision as of 15:20, 20 January 2023 by Wiki bot (talk | contribs)
Version 1.2
Category Environmental
Temp / Humidity (DHT22) component
The DHT22 temperature and humidity sensor is a popular sensor allowing the ambient temperature and relative humidity to be monitored digitally. Humidity Range = 0% - 100% +/- 2% Temperature Range = -40 - 80 Degrees C +/- 0.5 Degrees C
Please click here to download the component source project: FC_Comp_Source_DHT22.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_DHT22.fcfx
Example Program showing how to sample the DHT22 sensor and show the temperature and humidity on an LCD. DHT22 Example
GetTempWhole
Gets the whole number portion of the temperature returned by calling SampleSensor. If temperature is 15.8 degrees C then this function would return 15.
- INT Return
GetHumidityFloat
Gets the humidity returned by calling SampleSensor as a floating point number. If humidity is 15.8 % then this function would return 15.8.
- FLOAT Return
GetTempString
Gets the temperature returned by calling SampleSensor as a string. If temperature is 15.8 degrees C then this function would return "15.8".
- STRING Return
GetHumidityString
Gets the humidity returned by calling SampleSensor as a string. If humidity is 15.8 % then this function would return "15.8".
- STRING Return
GetHumidityWhole
Gets the whole number portion of the humidity returned by calling SampleSensor. If humidity is 15.8 % then this function would return 15.
- INT Return
GetTempReal
Gets the real number portion of the temperature returned by calling SampleSensor. If temperature is 15.8 degrees C then this function would return 8.
- INT Return
GetHumidityReal
Gets the real number portion of the humidity returned by calling SampleSensor. If humidity is 15.8 % then this function would return 8.
- INT Return
SampleSensor
Communicates with the DHT22 sensor and receives the temperature and humidity readings. Returns 0 for success, 1 for no communication detected and 2 for checksum error.
GetTempFloat
Gets the temperature returned by calling SampleSensor as a floating point number. If temperature is 15.8 degrees C then this function would return 15.8.
- FLOAT Return
SIG Pin
Microcontroller I/O Pin connected to the DHT11 sensor data pin.
Use Checksum
The checksum value is used to ensure the data being received is correct. Yes = Only receive data if checksum is correct No = Ignore checksum
Advanced Settings
Clock Adjustment
On 8-bit PIC devices the timings can be a little tight as slower clock speeds and so we implement an adjustment factor to allow the sensor to function. Auto mode will attempt to automatically calculate a correct adjustment factor. Manual mode will allow you to set your own adjustment factor.
GetTempWhole
- INT Return
GetHumidityFloat
- FLOAT Return
GetTempString
- STRING Return
GetHumidityString
- STRING Return
GetHumidityWhole
- INT Return
GetTempReal
- INT Return
GetHumidityReal
- INT Return
SampleSensor
GetTempFloat
- FLOAT Return
SIG Pin
Use Checksum
Advanced Settings
Clock Adjustment
GetTempWhole
- INT Return
GetHumidityFloat
- FLOAT Return
GetTempString
- STRING Return
GetHumidityString
- STRING Return
GetHumidityWhole
- INT Return
GetTempReal
- INT Return
GetHumidityReal
- INT Return
SampleSensor
GetTempFloat
- FLOAT Return
SIG Pin
Use Checksum
Advanced Settings
Clock Adjustment
